Calculating Beat Frequency in the Doppler Effect
The discussion focuses on calculating the beat frequency experienced by an observer when a boy walks away from a wall while blowing a whistle at a frequency of 680 Hz. The boy's speed is 1 m/s, and the speed of sound in air is 340 m/s. The observer hears two frequencies: one directly from the boy and another reflected from the wall. The calculated beat frequency is 2 Hz, derived from the difference between the observed frequency of 682 Hz and the original frequency of the whistle.
  • Doppler Effect principles
  • Understanding of beat frequency
  • Basic knowledge of sound wave propagation
  • Familiarity with the Doppler formula for frequency calculation
  • Study the Doppler Effect in detail, focusing on moving sources and observers.
  • Learn how to calculate beat frequencies in various scenarios.
  • Explore sound wave reflection and its impact on frequency perception.
  • Investigate the mathematical derivation of the Doppler formula.
Students in physics, educators teaching sound wave concepts, and anyone interested in the practical applications of the Doppler Effect and beat frequencies.
lha08
A boy is walking away from a wall towards an observer at a speed of 1 m/s and blows a whistle whose frequency is 680 Hz. THe number of beats heard by the observer is ____.
(Velocity of sound in air=340 m/s)
a) zero
b)2
c)8
d)4
For this question, I used f(observer)=f(source)v/(v-v(source)). In this case, when i plugged in the number i got 682 Hz...but the only thing i can think of is to subtract 682 from 680 Hz which gives 2...i don't know why if it's right though...
Observer hears two sounds, one directly from the boy who is moving with 1 m/s and another reflected from the wall which appears to be moving with 2 m/s.
how did you get 2 m/s?
If a person in front of a mirror moves towards you with a velocity 1 m/s, the image appears to be moving with 1 m/s with respect to the mirror away from you. And with respect to the person the image appears to be moving 2 m/s away from you. Same thing happens here.
So in every problem that's like this, when sound waves bounce off a wall, it will arrive to the observer at double the velocity?
Velocity of the sound does not change. If the source is moving towards you with velocity v, the image of the source moves away from you with velocity 2v.
what do you mean by "image of the source"?
You will be receiving two sounds. One directly from the boy and other reflected from the wall which can be taken as from the image of boy in the wall.
Huh? The wall is moving with 2m/s ? ... Your explanation is a bit unclear with the mirrors and so on.
So what is moving how fast with respect to what? And how is that useful?
I think it might be zero if there is destructive interference, I don't see how you could get 2, 4 or 8. I have no idea how to prove this though.
the velocity of the sound is independent of the source velocity...for an observer in rest relative to the air or any other medium.
well having no idea what "beats" mean I can't really help, but the note at the begging of the post should help.
and the velocity of the sound "bouncing" from the wall will be 340 m/s as well.
hope that helps in any way.
Why do you think that the image of the source moves away with twice the velocity? The image appears to be moving away at 1 m/s. (The wall is not moving.)
There are two sounds heard:
(1) The direct sound, the source of which approaches the observer at 1 m/s. Find that frequency using the Doppler formula.
(2) The reflected sound. The wall just reflects the same frequency that it receives. From the wall's point of view, the source moves away at 1 m/s. Find that frequency using the Doppler formula. (Since the wall is stationary, there is no second Doppler effect to worry about.)
You can also view the reflected sound as being produced by the reflected image, which moves away at 1 m/s. Same answer, of course.
Thank you Doc Al
