Doppler Effect on Light: Constant Speed of Light Confusion
The discussion centers on the Doppler effect as it applies to light, particularly in the context of the constant speed of light in a vacuum. Participants explore how the Doppler effect can occur without implying a change in the speed of light, addressing both theoretical and conceptual aspects of the phenomenon.
  • Some participants question how the Doppler effect can occur if the speed of light is constant for all observers, suggesting that a color or frequency shift might imply a change in speed.
  • Others argue that the observed shifts in frequency and wavelength do not indicate a change in the speed of light, as the product of frequency and wavelength remains constant.
  • A participant notes that in a vacuum, all colors of light travel at the same speed, which could explain the observed color shift without a change in speed.
  • It is mentioned that the Doppler effect involves the velocities of the source, receiver, and the periodic signal, which adds complexity to the understanding of the effect.
  • Some participants discuss the relationship between frequency shift and color shift, asserting that they are essentially the same phenomenon.
  • A later reply introduces the idea that longitudinal Doppler shift relates to time dilation and the distance light travels towards the receiver.
  • Another participant mentions that while light in a vacuum travels at a constant speed, the Doppler effect can also occur in dispersive media, where different colors may travel at different speeds.
Participants express differing views on the implications of the Doppler effect in relation to the speed of light. While some agree on the constancy of light speed and its relation to frequency shifts, others present alternative perspectives, indicating that the discussion remains unresolved.
Participants reference various aspects of the Doppler effect, including its mathematical treatment and implications in different media, but do not reach a consensus on all points raised.
InquiringMind
TL;DR
Doppler effect and constant speed of light
If the speed of light in the vacuum of empty space is the same for all observers, how can there be a Doppler effect on light? Doesn't the shift of color/frequency indicate a change in speed?
Sorry if I posted with the wrong prefix, I'm just a curious senior (as in old guy) :oldconfused:
InquiringMind said:
TL;DR Summary: Doppler effect and constant speed of light
If the speed of light in the vaccum of empty space is the same for all observers, how can there be a Doppler effect on light? Doesn't the shift of color/frequency indicate a change in speed?
No, it indicates a change in frequency and wavelength such that the product, which is equal to the speed, stays constant.
No - if the wavelength and frequency for one observer are ##\lambda## and ##\nu## and another observer measures wavelength ##\lambda'=\alpha\lambda## then they measure frequency ##\nu'=\nu/\alpha##. Then ##\lambda'\nu'=\alpha\lambda\nu/\alpha=\nu\lambda## so the wave speed is the same.
This is qualitatively similar to sound waves in a medium but the mathematical details are different.
I just read that in a vacuum, all colors travel at the same speed, so I guess that is why there can be an observed color shift without a change in speed.
As others said, it is the frequency shift. Here are some animations about the Doppler effect:
https://www.einstein-online.info/en/spotlight/doppler/
Sagittarius A-Star said:
No. As others said, it is the frequency shift. Here are some animations about the Doppler effect:
Frequency shift and color shift are the same thing. Hence terms such as "red shift" and "blue shift".
Just to make sure it's clear...
the Doppler effect is a relationship among three velocities:
  • the velocity of the source
  • the velocity of the receiver
  • the velocity of the periodic signal (e.g. light or sound)
Longitudinal doppler shift is basically just time dilation in combination with the fact that the light pulses travels longer and longer distance towards the receiver
Yes, I should have mentioned this.
Light moves in vacuum with the invariant speed and dispersion is not possible in vacuum, all colors travel at the same speed.
An observed color shift (Doppler effect) exists if the light moves in vacuum and also, if light would be sent through a dispersive medium. There, not all colors travel at the same speed. However, in this case the Doppler effect would be more complex.
You find a general treatment of the most simple case of light propagation in a dielectric and the Doppler effect here:
https://itp.uni-frankfurt.de/~hees/pf-faq/rela-waves.pdf
With "most simple case" I mean I consider only a monochromatic wave in a lossless medium with normal dispersion, i.e., concerning the optics the medium is described by a constant index of refraction, ##n>1##, i.e., the phase velocity of the wave ##c_{\text{s}}=c/n<c##.
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 45 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 16 ·
