Double integral over a rectangular region
10 replies · 4K views · last reply
Martyn Arthur
TL;DR
Area Integration
Hi I struggle with integration generally. Could you be able please to talk me through the stages of this one?
thanks
martyn
Worked example text for a double integral of y cos(xy) over the rectangle 0 ≤ x ≤ 2, π/2 ≤ y ≤ π, with a small graph of the shaded rectangular region of integration in the x-y plane.
Can you do the integral $$I=\int_0^2a\cos(ax)dx$$where ##a=~##constant? If so, what do you get? Do you see why the resut is a function of ##a##, i.e. you can write ##I=f(a)## which means "you give me a value for ##a## and I will give you a value for ##I##?"
It would be helpful if you told us exactly which parts you don't understand. If your answer is "all parts," then my suggestion would be to go back to the start of the section in your textbook where iterated integration is introduced.
BTW, questions like this one normally should be posted in the Homework Help section, under Calculus & Beyond, and should include your efforts to find a solution.
Thanks;
I did the underlying theory of integration in year one of the degree but the cross over to this second year has been difficult with little explanation.
I understand the basics of the overall thing, sin is a basic integral of cos et al.
I understand that integral 3 is integrating the second piece of the action.
I understand the maths of that calculation.
I am completely lost as to the overall mechanics of the conversion of sin to (-1/2cos).
Given that integral 2 produces a conclusion how do they fit together.
To try to make myself clear its the process that confuses me.
thanks
martyn
  • Calculus working showing the integral from x=0 to 2 of y cos(xy) dx equals the bracket of y sin(xy)/y from x=0 to 2, which equals sin(2y).
  • Calculus working: the integral from x=0 to x=2 of y cos(xy) dx equals the bracket [y sin(xy)/y] evaluated from x=0 to x=2, which equals sin(2y).
By reference to Mark44 thanks,
I take the point about homework which I note.
I hope my later post makes my problem more clear..
There is no adequate crossover in the text from the integration procedures which I understand to the practical application that is now produced.
I think some gentle support on the "bits" of a couple of points will see me through to a fuller understanding.
This integral is $$\int_{x=\pi/2}^\pi \sin(2y)~dy$$
Integration here is pretty straightforward, using a substitution; namely u = 2y, so du = 2dy, so dy = 1/2 du. This produces the (indefinite) integral ##\int \sin(u)~ (1/2) du##.
Can you evaluate that one?
Integral 2 is not the conclusion. It is the result of the integral in parentheses in integral 1.
I suspect at this level you are expected to recognise a common anti-derivative like this.
You guys are so patient. Given the following
xr^3(1-cos^2θ)cos^2θ
I need to make the substitution u = (1-cos^2θ) have I got it right?
Thanks
Handwritten derivation: Let c = (1 - cos²θ), f(u) = cos u, with d/dθ of cos²θ = -cos²θ; then the chain rule is applied to f(g(θ)) with g(θ) = cos θ, giving 2 cos θ d/dθ cos θ = -2 cos θ sin θ = -sin(2θ).
  • Mathematical expression: x r^3 (1 − cos^2 θ) cos^2 θ, written in typeset notation.
  • Typeset expression x r^3 (1 - cos^2 θ) cos^2 θ, written as an algebraic product in LaTeX-style math.
Thanks
I can't make any sense of this of the attachments. They are the same image double-posted and are as follows:
$$xr^3(1 - \cos^2)(\cos^2)$$
What does this mean? Why is ##\theta## missing from the attachments?
What are you supposed to do with this?
The work you show also makes little sense, partly because some of it is cut off, partly because it's hard to decipher, and partly because much of the rest doesn't make sense.
At the top you have "Let ##u = (1 - \cos^2\theta)##" and then <something> u = ##\cos u## <something>
In the 2nd equation on the left side you have a squiggle -- is it f? Or is it an integral sign? On the right side the top of the fraction is cut off. Is where I have ? supposed to be d?
On the next line you have ##\frac d {d\theta} = -\cos^2 \theta##
This doesn't make sense for a couple of reasons:
1) On the left side you have a differentiation operator, but are missing whatever it is that you are differentiating? Should this have been ##\frac{du}{d\theta}##?
2)Assuming that you meant ##\frac{du}{d\theta}## on the left side of the second line, the right side is not the derivative of ##1 - \cos^2\theta##
If the goal is to find the derivative of ##1 - \cos^2 \theta##, your answer at the bottom is correct, but there is a lot of cruft and incorrect stuff along the way.
Note that ##1 - \cos^2 (\theta) = \sin^2(\theta)## so
##\frac d {d\theta}(1 - \cos^2 (\theta)) = \frac d {d\theta}(\sin^2(\theta)) = 2\sin(\theta) \cdot \frac d {d\theta} (\sin(\theta)) = 2\sin(\theta) \cdot \cos(\theta) = \sin(2\theta)##
Thread closed. @Martyn Arthur, since this is a new problem, please start a new thread. The appropriate place for it is the Homework Help section, under Calculus and Beyond.
