Double Integral (underneath a surface and above a square)
4 replies · 2K views
letalea
The volume underneath the surface z= y/ (1+xy) and above the square {(x,y)| 2≤x≤3 , 3≤
y≤ 4} is:
Please see attachment.
Please see attachment for solution.
My professor had provided us with 8 possible solutions (where only one is correct). However the answer I had produced did not match with any of the 8. Any insight to where/how I went wrong is greatly appreciated!
Thanks in Advance!
y≤ 4} is:
Thanks in Advance!
Your solution looked good to me.
What were the eight choices given?
Added in Edit:
There is a mistake in doing each of the last two integrals.
You should have coefficients of 1/3 & 1/2 respectively.
Could you explain this mistake to me? As I am not seeing how I come to get the coefficients.
But yes you are right, when you factor in the coefficients it does give me one of the possible answers the prof gave us!
[itex]\displaystyle \int\ln(1+3y)dy[/itex]
Let u = 1+3y → du = 3 dy → [itex]\displaystyle dy=\frac{1}{3}du[/itex]
Can you take it from there?
Yes, that makes perfect sense. Thank you!
