Double integrals interchanging order
  • Thread starter jonroberts74
    Integrals
jonroberts74
[tex]\int_{1}^{4}\int_{1}^{\sqrt{x}}(x^2+y^2)dydx[/tex]
I drew the region,
I tried
[tex]\int_{1}^{2}\int_{1}^{y^2}(x^2+y^2)dxdy[/tex]
but it doesn't seem to work.
when the order is changed
[tex]1 \le y \le 2[/tex]
and [tex]\sqrt{x} = y \rightarrow x=y^2[/tex]
so the change in x is [tex]1 \le x \le y^2[/tex]
but it doesn't work out to the correct answer.
The region described by [itex]1\leq y \leq 2[/itex] and [itex]1\leq x\leq y^2[/itex] looks like this:
Plot of the curve x = y^2 for y from 0 to 3, with a shaded region bounded by horizontal lines y = 1 and y = 2 and a vertical line x = 1, and a vertical line x = 4 marking the curve's intersection with y = 2.
However, the region specified in the first integral is this one:
Plot of the curve y = sqrt(x) for x from 0 to 4.5, with the region between the curve, the line y = 1, and the vertical line x = 4 shaded in light blue, bounded by the curve above and y = 1 below, with axes labeled 0 to 3 for y and 0 to 4 for x.
Can you tell what the proper bounds should be from this illustration ?
  • Plot of the curve y = sqrt(x) on x from 0 to 4 and y from 0 to 3, with vertical lines at x = 1 and x = 4 and horizontal lines at y = 1 and y = 2, shading the region between the curve and the horizontal line y = 2 for x from 1 to 4.
  • Plot of the curve y = sqrt(x) on axes from 0 to 4 horizontally and 0 to 3 vertically, with the region between the curve, y = 1 and x = 4 shaded in light blue; the curve crosses y = 1 at x = 1 and y = 2 at x = 4.
I see it
the new integral should be
[tex]\int_{1}^{2}\int_{y^2}^{4} (x^2+y^2)dxdy = \int_{1}^{4}\int_{1}^{\sqrt{x}} (x^2+y^2)dydx[/tex]
