LaTeX Understanding Double Line in LaTeX to Using // for Line Breaks
  • Thread starter Thread starter Bachelier
    Latex Line
The discussion centers on the correct usage of line breaks in LaTeX, specifically addressing the confusion between using "\\" and "//". Users clarified that "\\" is the proper command for line breaks, while "//" is not accepted by the LaTeX compiler. Additionally, the old command "/linebreak[2]" is also ineffective. For creating larger gaps, commands like \bigskip, \medskip, or \smallskip are recommended over multiple "\\" to avoid warnings such as "underfull hbox".
  • Familiarity with LaTeX syntax and commands
  • Understanding of document structure in LaTeX
  • Knowledge of LaTeX environments for formatting
  • Basic troubleshooting skills for LaTeX compilation errors
  • Research the use of the "\\" command in LaTeX for line breaks
  • Explore the commands \bigskip, \medskip, and \smallskip for vertical spacing
  • Learn about LaTeX environments and their impact on line breaks
  • Investigate common LaTeX compilation errors and their solutions
LaTeX users, document authors, and anyone looking to improve their formatting skills in LaTeX documents.
Bachelier
What is double line in ##LaTex?## I tried ##"//"## twice, but the compiler does not accept it.
The old ##" /linebreak[2] "## command does not work neither?
Thanks
Thanks
Hi Bachelier! :smile:
Which double line do you mean in ##\LaTeX##?
Is it:
Code:
||   //   \backslash\backslash   \lVert   or   \parallel
These render as:
$$\quad || \quad // \quad \backslash\backslash \quad \lVert \quad \text{ or }\quad \parallel$$
In latex you can use \\ for a linebreak, although on this site it only works in a \begin{something} environment.
For instance:
Code:
\begin{aligned} a = b+1 \\ c = b-1 \end{aligned}
which renders as:
$$\begin{aligned} a = b+1 \\ c = b-1 \end{aligned}$$
Forgot to add the word "break" in my title. sorry.
Yeah I meant: "Doubleline breaks and more line breaks" to control the structure of one's document.
Thank you
Edgardo said:
You have to use "\\" and not "//" if you want a linebreak.
See here: http://www.personal.ceu.hu/tex/breaking.htm
That is what I meant. I was using "\\" but my compiler did not take it.
However the funny thing is that after rebooting my machine, now "\\" works for as many line breaks as I want.
Thanks for that doc. I tried "\\" but it just seems to give me a line break. It does not start a new paragraph like the website claims. \\* gives the same result.
On a different note my friends, to get line breaks (like 3 or 4) for styling the ##\LaTeX## document, is it a good modus operandi to use "\\" and "\\*"?
The website is wrong. (Given the .hu, maybe it lost something in translation from hungarian to english). The whole point of \\ is that it DOESN'T start a new paragraph (and therefore you don't get paragraph indentation, automatic extra space adjustment between paragraphs, etc).
Probably not. I'm surprised several \\ in succession works at all. Actually I just tried it and it did work, but gave an "underfull hbox" warning. I expected to get an error message like "There's no line here to end" or something similar.
If you want one big gap, do \\[24pt] or whatever size you need.
Or better, use \bigskip \medskip or \smallskip. Those vertical spaces are "stretchy" so they adjust a bit to fill up the page correctly/ They also disappear if they happen to be at the end of a page, which is probably what you wanted.
Thank you ##|\mathbb{Z}_{>0}|##
BTW, what is your favorite command for paragraph breaks (i.e. to begin new paragraphs in the document)?
  • · Replies 23 ·
  • · Replies 36 ·
