Double Pendulum Homework: Small Angle Approximation
The discussion revolves around solving the equations of motion for a double pendulum using small angle approximations. The first equation has been derived successfully, but the second equation remains elusive due to confusion over the forces acting on the lower mass and the tension in the strings. Participants emphasize the need to accurately account for the non-perpendicular relationship between tension and gravitational force in this context. Some suggest that using Lagrangian mechanics may simplify the problem, while others encourage a detailed breakdown of the Newtonian approach. Ultimately, the original poster resorted to Lagrangian methods after struggling with the Newtonian derivation.
zell99
A double pendulum consists of light, inextensible strings, AB and BC each of length l. It is fixed at one end A and carries two particles, each of mass m, which hang under gravity. The pendulum is constrained to move in a vertical plane. The angle between the vertical and AB is \theta, which the angle between BC and the vertical is \phi. Show for smll angles about the equilibirium position:
d^2\theta/dt^2 +g/l(2\theta -\phi)=0
d^2\phi/dt^2 +2g/l(\phi - \theta)=0
Newton's second law.
I shouldn't need to use Langrangian mechanics.
I've managed to derive the first equation, first by assuming the tension in BC is mg (small angle approximation) then resolving forces about the top mass, and using the small angle approximation for sin. But I just can't get the second result out. I've tried to do the same this (resolving forces) but I must be making a mistake somewhere. Any help would be appreciated. Thanks
Strange. I get the following for the force in the tangential direction of the mass at the end of BC:
ma = m \frac{dv}{dt} = m l \, \frac{d^2 \phi}{dt^2} = mg \sin \phi \approx mg \phi
Rearranging gives me:
\frac{d^2 \phi}{dt^2} - \frac{g}{l} \, \phi = 0
This does not look like what you want to show. Hmm...
Thnaks for the reply. I think what you're missing, and what I can't get the right value for, is that now the tension is no longer perpendicular to the gravitational force, due to the combination of strings, for the bottom mass. This will lead to an extra term but I can't get it to come out correctly.
If anyone knows I'd really appreciate it.
Thanks
Who said the tension is perpendicular to the graviational force? The tension is always parallel to the string.
Sorry my fault, should have been more accurate with words, (I don't think what I meant was right either). I'm still confused so if someone is able to derive or give me a hint towards the second equation I'd be really grateful.
Thanks
Anyone? please.
It's hard to say where you've made the mistake.
There's obviously more work involved using Newton's equations than Lagrange's -- therefore, you may have to post all your working for help...
(At soem point, you should have 4 equations for \ddot\theta, \dot\theta^2, \ddot\phi, \dot\phi^2 from which the tensions in terms of \ddot\theta, \ddot\phi, \theta, \phi can be found...)
Thanks for the reply. I gave up in the end and used the Langrange.
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 26 ·
