Double-slit experiment and time
24 replies · 3K views
Enlanda
TL;DR
I was interested in whether anyone had conducted experiments that would reveal unusual properties of the particles being experimented on from the point of view of time.
Talking to my AI assistant about the Double-slit experiments that have been conducted many times, I was interested in whether anyone had conducted experiments that would reveal unusual properties of the particles being experimented on from the point of view of time.
For example, place one slit directly opposite the particle projector so that the electron would get there at a right angle along the shortest distance, and the other slit very far from the projector, say to the right or left at an acute angle. At such a distance that it would be possible to detect the difference in time with which the observed particles passed through these two differently located slits.
In order to confirm or refute the assumption that a particle in a quantum state will pass through both slits at the same time or will go to the far slit faster than to the near one.
The AI answered my question in the negative. It had no information about such experiments.
I described only one example that came to my mind off the top of my head. But I would like to know about any experiments studying entanglement in terms of time anomalies, rather than space or energy, that have already been confirmed.
You may have been misled by non-technical descriptions in the popular press, because the double-slit experiment is not like you are thinking.
There is no “in a quantum state” or not, the particle is always in a quantum state and the “wave-particle duality” you may have read about is a misconception abandoned almost a century ago. It makes no sense to talk about the particle passing through one or both slits at the same or different times, that’s just not how quantum mechanics works.
What is true, and has been tested many many times, is that interference only happens when the lengths of the paths through the two slits differ by less than a certain amount (the “coherence length”, a property of the incoming particles).
You might give Giancarlo Ghirardi’s book “Sneaking a look at god’s cards” a try. It’s a layman-friendly explanation of quantum mechanics that avoids some of the worst popular misunderstandings.
(And be very cautious about anything an AI says. They do some things very well, but separating good information from bad is not one of them - which is how the AI didn’t tell you that everything you had heard about the experiment was wrong. Indeed, they are so unreliable for this purpose that the forum rules do not recognize anything they say as a valid reference).
Reply
In practice, the double-slit experiment requires that the slits be close together. If they are too far apart, then either you get have two separate single-slit experiments; and/or, most of the source is absorbed by the barrier between the slits and doesn't get through, so you see nothing.
It usually requires a delicate configuration of the experimental apparatus in order to see the underlying QM interference. Otherwise, the experiment becomes what is technically known as incoherent, and the interference effects tend to get washed out.
Reply
This is very interesting. Thanks for the explanation.
And what if instead of moving the slits at different distances from the projector. We put not one, but two screens in the path of what comes out of the different slits? So that what comes out of one slit gets on the near screen and what comes out of the second slit gets on the far away one.
Is it possible to conduct an experiment with the properties of time in this way?
QM is quite logical once you use the mathematics of the wavefunction. The detector screen has to be far enough away from the slits for the interference to be practically detectable.
If you close one slit, you get single slit diffraction. The further the detector screen, the wider the diffraction pattern.
That said, if the slits are close together, then there is no much room to have two detector screens.
PS note that a lot of popular sources give the impression that the light or particles behave differently when there are two slits, than when there is only one. Even Jim al-Khalili in his lecture at the Royal Institution presented this quite explicitly.
The reality is that if each slit is too wide to produce significant diffraction, then two wides slits will produce little or no interference. It will just be two bands of light. Like you get through window blinds, for example.
What happens when there are two narrow slits is that you get diffaction from each and the diffraction patterns overlap. And the overlapping patterns produce a different interference pattern. There is no mystery here when you use a classical wave theory. There is also no mystery when you use a QM wave-function - which explains why an electron diffracts and interferes with itself; and why ultra-low-intensity light (one photon at a time) diffracts and produces an interference pattern.
The mysteries are sustained, IMO, by a half-hearted acceptance of QM, which still aims to explain things in terms of classical concepts of wave and particle, somehow scrambled by QM. Whereas, the classical concepts of wave and particle emerge from a single QM model. If you start with QM, there is no mystery. It's only when you insist on continuing to think classically that you get tangled up in apparanetly mysterious behaviour.
Reply
Yes. I think I understand what the problem is with both of my proposals.
Did I understand correctly that when an electron in the form of a wave penetrates two closely spaced slits, we see approximately the same picture that we would observe in a calm sea. We would have a breakwater with two narrow slits and a wave, say a small tsunami, would go to the shore, meeting the breakwater on its way?
A tsunami wave, although expressed and visible by means of water molecules, still has a clear energy born thanks to, say, an underwater earthquake. And this pure invisible energy gives itself away by moving water molecules.
Thank you very much for this explanation. Yes, I myself have encountered the unreliability of AI when it comes to information. Sometimes it slipped me its own calculations when it could not find links to real ones. I will try to read this book.
So in practice there is nothing super unusual in either quantum entanglement or quantum superposition?
P.S. Still, by sending me to this forum, AI did me a good deed. :)
The first thing to understand is that at a certain level of precision, the electron appears to be a classical point particle with a well-defined trajectory. If you look more closely, the electron has an uncertainty in position and cannot be described as a point particle beyond a certain level of precision. When it passes through a slit (or a crystal that acts as a diffraction grating), the more precise QM model is needed. There is the concept in QM of a minimal-uncertainty wave packet. This is a state of a single particle that has effectively as little uncertainty as possible. Once the scale of the slits is on the scale of this minimal uncertainty, then the probabilistic wave-packet that describes the electron extends across both slits. And then the phenomena such as diffraction and double-slit interference are fully observed. But, the electron always was described by a probabilistic wave packet. If the slits are too far apart, then the wave-packet can only practically extend over one slit, not both. And, if the slits are too wide, the wave-packet only extends across some of the slit and effectively passes through like a particle would.
This explains the experimentally observed wave-particle duality, without the electron inherently having any such duality.
This is the only way to understand QM. That the probabilistic wave-function/wave-packet exhibits both classical particle-like and classical wave-like behaviour, depending on the characteristic of the experiment. In the context of a free electron fired at a screen, it always is a probabilistic wave-packet - it's not a classical wave and it's not a classical particle. It's a quantum object.
Did I understand correctly that a wave packet is the width, height and depth of a wave that describes all possible positions of an electron, thus creating a "wave packet"?
P.S. In other words, an electron is not a point but a sphere?
It's not a sphere. It's important to recognise that a wave-packet is a mathematical description of an electron in terms of a complex-valued wave-function. Technically it describes a complex probability amplitude; not even an actual real probability.
This is the intellectual step that understanding modern physics demands: that objects at the sub-atomic scale are described by mathematics only. Technically, a wave-packet extends over all of space, but it can be highly localised. The probability of an electron in a localised state interacting with a slit even a few centimetres away is effectively zero. This is why the slits cannot practically be far apart: the probability (amplitude) of interaction with a slit becomes almost zero.
For example,
https://en.wikipedia.org/wiki/Wave_packet#Gaussian_wave_packets_in_quantum_mechanics
To go further, you need to start to grasp the mathematics.
Reply
For both PeroK and PeterDonis.
I'll make one last attempt to understand it on my own, then I'll go read Giancarlo Ghirardi's book. :)
A quantum object is information. Something that is the same fundamental basis of the universe as time, energy, space.
No, it's a quantum object.
I don't know where you're getting this from.
Reply
I see.Thank you. Maybe the book will help me. :)
Reply
It depends on what you consider "super unusual". The behavior of quantum objects is different from anything we have experienced in a lifetime spent with classical objects, so our common sense about how things should be just doesn't work. For example: things have positions? Nope. If a particle is emitted at point A and detected at point it must have been somewhere in the space between A and B? Nope. The number of left-handed men in a room cannot be greater than the number of left-handed non-smokers of either gender plus the number of men who smoke? That logic works for classical objects but not quantum objects.... and many more things that you might consider super unusual, weird, counterintuitive.
However, these are all cleanly described by the math - at small scales the world works the way the math says it does, it's just not what we expect. Analogies like "wave", "particle", "goes through two slits", "position is spread out" all fail because they are referring to classical concepts and quantum behavior isn't like that, but when we apply the math it's all clear.
This is why in your other thread @PeroK said "Physics deals with those, largely through the use of mathematics". Math is the language of quantum mechanics, and studying QM without the math is like studying art through written descriptions instead of looking at the paintings.
Reply
Nugatory said:
It depends on what you consider "super unusual". The behavior of quantum objects is different from anything we have experienced in a lifetime spent with classical objects, so our common sense about how things should be just doesn't work. For example: things have positions? Nope. If a particle is emitted at point A and detected at point it must have present somewhere in the space between A and B? Nope. The number of left-handed men in a room cannot be greater than the number of left-handed non-smokers of either gender plus the number of men who smoke? That logic works for classical objects but not quantum objects.... and many more things that you might consider super unusual, weird, counterintuitive.
I agree and am glad to learn something new.
So, ordinary logic does not work in the quantum. And what logic works?
I read that quantum behavior of objects is possible only in the micro world. But aren't black holes objects that, thanks to their unique energy force, make macro objects behave like that quantum objects in the micro world. At least, that's what it seems like from a general view.
Maybe ordinary objects near us do not behave like quantum objects only because in the ordinary world near us there is no energy capable of making them behave this way. It is enough only for microparticles.
I apologize again for my terminology. I am not a physicist, not a programmer. But I was interested in logic, or rather, as it seems to me, in its complete absence that we observe in the behavior of quantum objects.
Ordinary logic works just fine. But logic starts with premises, and some of the premises that think are obviously true turn out not to be, and then logic and math take us places that seem counterintuitive or even impossible .
That's not quite right. Quantum mechanics always governs.
What's actually going is that that in any macroscopic situation that we're ever going to encounter all the quantum weirdnesses average out and the overall behavior looks classical. It is similar to how we think about gases and pressure: We know that a gas is made up of individual atoms bouncing around in random directions and hitting the sides of the container. However, when we do the math (this is a branch of classical physics called statistical mechanics) we find that there are so many atoms bouncing around that there will always be about the same number hitting all sides of the container, hence a uniform outwards pressure - the fluctuations are too small to detect. And once we know that we can treat the pressure as a macroscopic property of this macroscopic quantity of gas, no need to apply Newton's laws to each individual atom. Likewise, no need to do a complete quantum mechanical analysis of each particle in a macroscopic object when we know that it will average out to classical behavior.
You will not find any reputable source that says anything of the sort... although there is no shortage of interesting problems involving quantum mechanics n strong gravitational fields, that's not how it works.
Reply
@Enlanda, You may also be interested in the following experiments:
Quantum interference by a nonlocal double slit
E. J. S. Fonseca, P. H. Souto Ribeiro, S. Pádua, and C. H. Monken
Phys. Rev. A 60, 1530 – Published 1 August 1999
https://journals.aps.org/pra/abstract/10.1103/PhysRevA.60.1530
We report an interference experiment in which photon pairs generated by spontaneous parametric down-conversion produce a Young-type fourth-order interference pattern after being scattered by two different and spatially separated apertures, whose superposition defines a double slit. The experiment is compared with previous ones based on parametric down-conversion, and its nonlocal nature is discussed. A theoretical explanation is also provided.
Interference fringes from stabilized diode lasers
Lorenzo Basano; Pasquale Ottonello
Am. J. Phys. 68, 245–247 (2000)
https://doi.org/10.1119/1.19416
Interference fringes produced by a pair of intracavity stabilized diode laser beams, each impinging separately on one aperture of a double slit, are recorded on a linear charge-coupled device array. The peculiar result of the experiment is that the fringe system is found to persist for a time of the order of 1 ms and loses contrast for longer integration times. This implies that the individual linewidths of the two beams from the stabilized lasers are narrower than 1 kHz and that the average drift rates of the central peaks are far less than 0.1 MHz/s. The device was built within the advanced undergraduate electronics laboratory of the department of physics and represents a considerable improvement over previous demonstration apparatuses used to detect interference fringes from independent lasers.
Reply
Thank you very much for your explanations and patience. I think I will read a couple of books on this topic before I make any more statements or ask questions. :)
The description looks terrible to me. Let's see if I'll have the desire to delve into it after reading popular literature on quantum theory. :)
Reply
  • Sad
Vanadium 50 said:
It may be too late to rerail this thread, but when did electrons get into this? The double-slit experiment with light explores classical wave behavior (of lifgt).
If the OP has something else in mind, it is best to be explicit.
The initial post specified "electrons", and everything from that beginning is applicable to any particle at a time experiment, whether using photons or electrons .
It seems that poster has managed (possibly just by luck) to avoid the classical waves trap set by so many pop-sci sources.
