Double Slit Experiment without the small angle approximation
9 replies · 9K views
Punkyc7
Two very narrow slits are spaced 1.8 [itex]\mu[/itex]m apart and are placed 35.0 cm from the screen. What is the distance from the first and second dark lines of the interference pattern when the slits are illuminated with coherent light with [itex]\lambda[/itex] =550 nm
r1-r2=m[itex]\lambda[/itex]
dsin[itex]\theta[/itex]=m[itex]\lambda[/itex]
Rtan[itex]\theta[/itex]=y
Since I am only concerned with the distance i was thinking about just finding the distance between the bright fringes. The problem is I don't know how to get theta.
Ive tried m[itex]\lambda[/itex]=dsin[itex]\theta[/itex] and solved for theta but that didnt work. I am not sure you can find r1 and r2 because the distance between the fringes is missing.
on Phys.org
You can use [itex]\theta = \arctan \frac{y}{R}[/itex].
The problem is we don't know y that is what I am trying to find, but I am going to need[itex]\theta[/itex] first
SammyS is right, the problem asks about dark fringes. For them, the angle of deviation from the central line is related with d and λ as
d sin([itex]\vartheta[/itex])=(2m+1)λ, with m=0, ±1, ±2 ...
y is the distance of a dark spot from the centre of the interference pattern on the screen. If the screen is at D distance from the two slits, tan([itex]\vartheta[/itex])=y/D.
You need the distance between the first and second dark lines. For the first one, m=0, and m=1 for the second one.
Calculate [itex]\vartheta[/itex]-s with m=0 and m=1, calculate the corresponding y values and find their difference.
ehild
isnt the distance between the dark fringes the same as the distance between the bright fringes?
so i would do
dsin[itex]\theta[/itex]=[itex]\lambda[/itex]
and dsin[itex]\theta[/itex]=3[itex]\lambda[/itex]
solve for [itex]\theta[/itex] in terms of y and then solve for y
so i would do
The values sin[itex]\theta[/itex] are equally spaced, but the position of the fringes are proportional to tan[itex]\theta[/itex].
I am sorry, there is a mistake in my last post, I meant
dsin[itex]\theta[/itex]=(2m+1)[itex]\lambda[/itex]/2
So calculate the distances from
dsin[itex]\theta[/itex]=[itex]\lambda[/itex]/2
and dsin[itex]\theta[/itex]=3[itex]\lambda[/itex]/2.
ehild
Just to clear something up, If we were using the approximation then the bright and dark fringes would be the same length.
Thank you so much for your help
