Double slit interference with small angle approximation
8 replies · 3K views · last reply
jegues
See figure attached for problem statement as well as my attempt
I don't know where to go from here. Can someone help me get started?
  • Handwritten work on graph paper beside a printed multiple-choice problem about single-slit diffraction of red and green lasers at 3.2 m, with wavelengths λr = 633 nm and λg = 532 nm and slit-to-screen distance L = 3.2 m marked.
Redbelly98 said:
Single slit diffraction . . . there is a standard formula for this. Look in your textbook.
I'm aware but I don't know how to deal with two separate lights at the same time, who's wavelength are different.
Can you clarify that portion?
The diffraction patterns are also separate, independent of each other.
ehild
ehild
I'm still having a really tough time with this problem. All I can identify is that,
[tex]dsin\theta_{r} = m\lambda_{r}[/tex]
and
[tex]dsin\theta_{g} = n\lambda_{g}[/tex]
so,
[tex]m\lambda_{r} = n\lambda_{g}[/tex]
Where m = 3, so n =3.5 therefore the nearest minimum would be at 3 for the green laser.
Now how can I calculate the difference between these two minimum on the screen?
Any help would be greatly appreciated, I'm really lost.
Find the distances from L and sin(theta).
ehild
ehild
I don't understand where sin(theta) is situated.
I know that L is the distance between the screen and the slit but where is sin(theta)?
Theta is the angle in the triangle like so, correct?
I don't know where sin(theta) is so I'm having trouble finding the distance between that and L.
One could say that sintheta is simply opposite over hypotenuse, but I don't know either of those sides.
  • Right triangle with a right angle at the bottom right, angle theta at the bottom left vertex, and the base labelled L in red.
Also, at small angles (as occur in this problem), θ, sinθ, and tanθ are all approximately equal to each other.
