Double Slit detectors question
The forum discussion centers on the implications of detectors in the double slit experiment and the concept of "observation" in quantum mechanics. Participants emphasize that detectors do interfere with the experiment, leading to different results when present versus absent. The discussion highlights that quantum objects exhibit wave-particle duality, but this concept is outdated; instead, they behave as excitations of quantum fields. The challenge in providing a mathematical explanation for "observation" stems from its vagueness and the complexity of translating quantum laws into classical measurement results.
  • Understanding of quantum mechanics principles
  • Familiarity with quantum decoherence
  • Knowledge of wave-particle duality
  • Basic concepts of quantum field theory
  • Research quantum decoherence and its mathematical framework
  • Explore the implications of the quantum eraser experiments
  • Study the differences between classical and quantum measurements
  • Investigate the role of information in quantum mechanics
Physicists, students of quantum mechanics, and anyone interested in the philosophical implications of observation in quantum experiments.
jacobassett
My question about the double slit experiment is this: why is it that nobody suspects that the detectors used to detect particles as they pass through the slits in the double slit experiment aren't causing some interference with the experiment which makes it seem as though they are acting like particles? Why can't physicists give a good mathematical explanation for what constitutes "observation"?
Hi jacobassett!
If you have not heard about quantum decoherence, you could have a look at it: Quantum decoherence (as a starter).
Yeah so why do people think it's so phenomenal that these waves act like particles then?
Suppose when I was not looking at you, you were an elephant. But every time I look at you, you turn into a human. Wouldn't you think that was weird?
I can not really speak for others, only for myself, but I will give it a try... One thing people seem to get hung up on is the so-called wave-particle duality, but this is an outdated concept (see the forum FAQ). One counterintuitive thing is that quantum objects interfere, yet when they are detected they are only detected as discrete units, i.e. as whole, and each object is detected in only one place at a time. Quantum objects neither behave like classical* particles nor classical* waves (* and with "classical" I mean like we are normally used to in our macroscopic world, i.e. they do not behave like billiard balls, marbles or sound waves and water waves). They behave like quantum objects as described by quantum mechanics. A more modern/advanced view is that they behave like excitations of an underlying quantum field in quantum field theory.
DennisN said:
I can not really speak for others, only for myself, but I will give it a try... One thing people seem to get hung up on is the so-called wave-particle duality, but this is an outdated concept (see the forum FAQ). One counterintuitive thing is that quantum objects interfere, yet when they are detected they are only detected as discrete units, i.e. as whole, and each object is detected only in one place at a time. Quantum objects neither behave like classical* particles nor classical* waves (and with "classical" I mean like we are normally used to in our mascroscopic world, i.e. they do not behave like billiard balls, marbles or sound waves and water waves). They behave like quantum objects as described by quantum mechanics. A more modern/advanced view is that they behave like excitations of an underlying quantum field in quantum field theory.
Yes I understand that part of it that's not what i was trying to clarify.
Well yes but under just the right circumstances there is a situation where that could be true no matter how improbable.
Ok. Please be more specific... :smile:
The detectors do "interfere with the experiment"; that's why you get different results when the detectors are present than you do when they are absent. So it certainly isn't true that "nobody suspects" that the detectors have an effect; their effect is the standard explanation for the change in the results.
Because, first, "observation" is too vague a term, and second, we don't fully understand how the "classical" measurement results we observe are produced from the underlying quantum laws. Decoherence is a key part of the picture, though, and there is certainly plenty of mathematical theory connected with that.
I would certainly say that has been considered. However, there is plenty of convincing evidence to the contrary.
An example may assist: if you place 2 polarizers, one each, behind the 2 slits, and there is no camera to otherwise record the path taken: If they are parallel, there WILL be interference. If they are perpendicular, there will be NO interference. The reason is that it would be possible to observe the polarization of photons as they hit the screen and determine the path when the polarizers are perpendicular. You don't actually need to take that step though, to eliminate the interference.
So the moral is: if a photon were going through *only* 1 slit or the other, the relative orientation of the polarizers - parallel or perpendicular - shouldn't matter. But in fact it makes all the difference. And that is because the polarizer orientation affects whether the photon is "wave-like" or "particle-like" (in simple terms).
Note that there are no detectors. But the quantum rule still applies: if you could have known, in principle, which slit the particle passed through, there will be no interference.
The quantum eraser experiments show that it is not due to interference, but to information.
"Observation" can be a confusing term. Usually people think of it as detection or measurement. However, an "observer" can also pre-select the boundaries and possibilities of what can be measured by the way they set up an experiment. On top of that, what an "observer" sees is conditioned by their frame of reference. So different "observers" see things differently. As scientists we don't like all that subjectivity so we try to interpret what they see as pertaining to an objective "reality" by involving theoretical concepts. Do you see why it makes sense to break the whole idea down and look at each aspect separately?
The laws of physics are the same in all inertial frames.
Observables in GTR are defined as scalar contractions of tensors, which are invariant.
Yes, of course. That's a fundamental assumption and our job is to discover what they are. This involves theory as well as experiment and requires us to relate the differing observations of differing observers.
Which is one of the theoretical tools by which we make those relations.
"The quantum eraser experiments show that it is not due to interference, but to information"
Reference https://www.physicsforums.com/threads/double-slit-detectors-question.890825/
Yes this can be deduced from the experiment, but how does one gather information without observation, and how does one observe
(detect) without affecting the observed quantum object.
The next question would then be. Was the information there(or the same) even though we don't make an observation?
Back to the same debate , "is the moon still the same as before I observed it".
Are there any other references in the forum where this has been covered?
The subject remains unanswered in my view?
The fact that we get an interference pattern without detectors is enough ..isn't it?
This is not the case, however. (I mean regarding whether or not there are detectors.) Note the comment about information below.
Which is not quite correct either. So let me clarify the double slit rules:
1. You can have detectors on both slits (polarizers work for photons). If they are oriented one way, there IS interference. Another way, NO interference. If the configuration gives you which path information, there is NO interference.
2. You do not actually need to receive the information. If there is merely the possibility (potential) that the information is "out there", there will be NO interference.
It is NOT the physical detector disturbing the photon as it goes through one side or the other that leads to NO interference. It is the possibility of learning which slit a particle goes through that is critical. This may not be the only way to state the rules, but it does get some essential ideas across.
oh, my last comment is very confusing for this thread, sorry. I merely meant when the double slit experiment is conducted without path information ..we get interference. It's telling use that the particle acts like a wave even if we are observing it from our (real world) scale.
I have deleted a bunch of posts that were off topic. Please keep this thread to a discussion directly related to the OP's question.
The word possibility is for me a grey area, it leads me to a paradox.
If it is possible, then the information exists somewhere , not so? Whether it was recorded or not.
So why should this be the deciding factor as to whether the interference pattern was formed or not.
Is it not more logical to say rather that.
"The 'process' of making the information available to us , has some influence on whether we measure the interference or not?"
This is a case where the information exists and is theoretically available, but no conscious observer sees it. So there is NO interference, and no paradox I am aware of.
By *why* is nature that way? I don't think there are good answers for questions like this.
The detectors only ever detect the particle as a particle though.
Unlike similar experiments with mechanical waves in a fluid (air, water, whatever) the quantum interference at slits experiment never has anyone observe any wave between the source and the detector. You realize you can put the detector anywhere you like, even over one of the slits.
People conversant with the modern formalism of quantum mechanics do not usually do that - that would imply wave-particle duality, which you have indicated you understood is no longer a thing.
A lot of the confusion around this sort of thing comes from being a bit glib about what the quantum interference at slits experiment actually does.
My goto B-level explanation thing is the Feynman lecture on this stuff - as a good starting point. It has aged well and quite accessible.
http://www.vega.org.uk/video/subseries/8
... see all the videos. The entire description uses only the particle model fro a "shut up and calculate" perspective.
For a more formal "A" description that invokes "measurement" ideas see
Rothman and Boughn (2010) Quantum interference at slits revisited (including how you get wave behaviour from particles)
https://arxiv.org/abs/1009.2408
... but also see the Marcella (2007) paper cited in the abstract for more detail on what is measured (idealized) and where.
https://arxiv.org/abs/quant-ph/0703126
... they are both very mathy, but it should provide an idea of how the "B" level description is not going to get you there.
Reference https://www.physicsforums.com/threads/double-slit-detectors-question.890825/page-2
Agreed. My point is that. It is in the process of making the information available that causes the interference to disappear.
Whether that is unavoidable seems to be the million dollar question. Personally I think not.
And I believe , QM is silent/unclear on this process.
Totally agreed! The "why" comes from not accepting current interpretations as to "how" this happens.
Although I don't have one myself..
Thanks for the insights.
Regarding the famous experiment? https://en.wikipedia.org/wiki/Delayed_choice_quantum_eraser#The_experiment_of_Kim_et_al._.282000.29
Would the following be an accurate paragraph.
If the signal photons are local and 'Alice' records the results at D0.
But the idler photons need to travel 1 light year to 'Bobs' detectors D1-D4.
Then the pattern type Alice records is totally dependent on 'Bobs' setup. For example
1. If Bob decides to remove the Detectors ( D4,D3) and mirrors (Sa ,Sb) during the idler photons flight before the first idler photon arrives
. Then Alice MUST(have) observe(d) interference.
2. If Bob decides to replace the mirrors (Sa, Sb) with 100 % reflecting mirrors. I.e. all photons are directed to D4 and D3 , during the idler photons flight.
The Alice MUST(have) observe(d) NO interference.
So Alice's result today will depend on Bob's decision in a years time.( Even though Alice will only receive the results 2 years later).
But the effect on Alice's results depends on Bob's decision in Alice's future??
Is this correct?
So Alice's result today will depend on Bob's decision in a years time.( Even though Alice will only receive Bobs DATA 2 years later).
But the effect on Alice's results depends on Bob's decision , in Alice's future??
Just clarifying my statement better.
Alice's results will not change, whatever Bob does. Alice will not see anything special in her results, and it is only when she receives Bob's results that she will be able to detect a pattern by comparing both results (what used to appear random is not random anymore).
Why should Alice's results be random? Depending on what Bob does in post 24# : either there is an interference pattern or there is not.
There are no subsets on D0 signal photons.
The choice by Bob will either detect which slit ALL the photons went through. OR erase which slit ALL the photons went through?.
There is never interference pattern in D0 detections.
Alice can't see interference pattern. She can "see" two complementary interference patterns only when she sorts her detections in two subsets using Bob's detections in D1 and D2.
Look carefully at figure 3. R01 and R02 in wikipedia article. There crest in one graph correspond to troughs in other graph. When both are added together there is no interference.
You can look at this post for answer why there is no interference pattern in D0:
https://www.physicsforums.com/threads/delayed-choice-quantum-eraser-again.885423/#post-5619033
All "why" questions in science have a straightforward answer: "because this is what is observed".
Serious science is to understand/compute "how". Other why questions are irrelevant (Feynman explains it quite remarkably)
This is false. The wiki page is pretty clear about that.
from wiki said:
The total pattern of all signal photons at D0, whose entangled idlers went to multiple different detectors, will never show interference regardless of what happens to the idler photons
Absolutely, there is random noise. Because:
from wiki said:
Somewhat beyond the path split, the idler photons encounter beam splitters BSa, BSb, and BSc that each have a 50% chance of allowing the idler photon to pass through and a 50% chance of causing it to be reflected. Ma and Mb are mirrors.
This is not about choice. This is about information about a single entangled pair of photon going to 5 detectors.
Thanks for the reference links
This clears it up.
So for the case however that there were only 2 detectors on the idler photons path (showing the which way path of the photon).
Then I assume each detectors signal photon would be superimposed as 2 non interference patterns. I.E. just 2 clumps , superimposed onto each other at D0.
And if the detectors erased the which way path the instead of revealing them , the subsets on D0 would be complimentary interference patterns.
If this is the case.
Then my question(s) is(are) :
When does this correlation between Bob and Alice's data manifest itself.
1. After Alice's recordings but before Bob's recordings.
2. After Alice's recordings and after Bob's Recordings
3. After Alice and Bobs recordings have been compared.
And further if the answer is 3 above, does it imply that the correlation could not exist ,between the time interval of event 2 and event 3?
Or even between event 1 and event 2 for that matter?
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 24 ·
  • · Replies 49 ·
