Double Slit Wave Interference Question
1 reply · 4K views · last reply
chudzoik
Blue light (λ = 482 nm) is directed through parallel slits separated by 0.15 mm. A fringe pattern appears on a ascreen 2.00 m away. How far from the central axis on either side are the second order dark bands?
λ = 4.82 x 10-7 m
d = 1.5 x10-4 m
L = 2.00 m
m = 2
y= ?
sin θ = (m + 0.5) λ/d
y = L tan θ
I used m = 2 (second order dark bands) and used the first equation which gave me the angle formed between the central axis and the second order dark band, which came out to be 0.46 degrees. I then used the second formula, which is the formula for the distance between the central bright fringe and any point on the screen, which gave me 0.016 m or 16 mm. The textbook says 38 mm, but I'm sure I've done it correctly
Your calc checks out.
I took m = 0 as being the first order dark fringe and m = 1 as the second order, which works out to 9.6 mm.
I don't see any way to get 38!
