Double Valve Spring: Benefits & Reasons
  • Thread starter Thread starter anhtho
    Spring Valve
The discussion centers around the use of double valve springs in motorbike engines, exploring the reasons for their design, benefits, and historical context. Participants examine the mechanics of valve operation, damping effects, and changes in spring technology over time.
  • Some participants suggest that double springs help avoid valve float by preventing extended operation at resonant frequencies.
  • Others mention that classic British motorcycles, such as those from Triumph and Norton, commonly use double valve springs, with claims that the springs rub slightly to create a damping effect.
  • A participant questions the longevity and potential damage of the damping effect between the springs, proposing that different surge frequencies might be a reason for using two springs instead of one.
  • Discussion includes the historical shift back to coil springs after 1945 due to airflow issues and mentions that modern coil springs are designed to prevent surging through friction damping.
  • One participant notes that newer engines tend to use shorter single coil springs, suggesting advancements in valve mass and travel distance have reduced spring-related issues.
  • A participant shares an experience with a specific engine design that utilized a flat strip of steel as an inner spring, highlighting its significant damping effect.
Participants express various viewpoints on the benefits and mechanics of double valve springs, with no clear consensus on the primary reasons for their use or the effectiveness of damping between springs.
Some claims about historical designs and modern advancements in spring technology remain unverified, and there are unresolved questions regarding the durability and performance of different spring configurations.
anhtho
In some motorbike engines, I notice there are two springs (inner and outer) for a valve. Why do they have to make it two ?
Thanks
Avoiding extended operation at resonant frequency valve float.
Thanks
In engine valves? Can you specify which bikes too?
which bikes?
Many "classic" British motors have double valve springs. Triumph, Norton, Vincent, etc. I don't know firsthand about newer / Japanese designs. I was always told the springs rub slightly creating a damping effect, preventing valve float (as Doug says above). They don't rub much though, once they kind of polish each other. So maybe the two spring constants have an effect on the resonance other than the purported rubbing/damping.
What gmax said is true, but I've wondered about the damping between the springs myself. How long does that last, and does it damage the springs? It could certainly be to have two different "surge frequencies" so that instead of the whole spring mass surging to cause float, only one spring at a time does. But that means one would have to be lower than the other - why not make them both high - and then why not just have one spring?
I have seen "beehive" springs that are pretty cool, because they minimize the mass at the moving end of the spring, which delays surge.
P.E. Irving in Tuning for Speed said:
After 1945 there was a change back to coils, largely because of the difficulty of enclosing hairpins without serious interruption to air-flow through the head fins, particularly on a parallel twin. Coil-spring fracture is mainly caused through "surging" or a state of rapid vibration of the centre coils; all modern coil springs are duplex with not more than six free coils in the outer. The inner spring often has one or two more coils of lighter gauge wire and it is an advantage for it to be a push fit within the outer one as this provides a certain amount of friction damping and so helps to prevent surging.
This written in 1948, I don't know if today's modern engines use the duplex springs. Probably metallurgy has moved along in the intervening decades and modern springs don't fracture the way they did in the 1940s. Maybe someone can comment on the current valve springs?
By the way if you are not familiar with Phil Irving you're missing out. Velocette, Vincent, Brabham F1; take a look here:
http://en.wikipedia.org/wiki/Phil_Irving
Most newer engines (~10 years old) that I repair contain a shorter single coil spring with fewer turns than older designs. I think valve mass and travel distance has been reduced to the extent that valve spring issues are virtually unheard of in consumer engines.
The first engine that I ever worked on (1970's small block Chevy V8) had a flat strip of steel wrapped around in a tube shape type of inner spring. I tried taking the inner spring out once and it was quite difficult to twist the inner spring in order to get it to move from within the outer spring. The strip was about twice as wide and half as thick as the outer round coil wrapped the opposite direction. I estimate that adds up to quite a lot of dampening! The last one I built about 10 years ago had larger valve diameter with a smaller stem and guide with high performance single coils, and a roller cam and rockers of course.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 19 ·
