Drag, terminal velocity, and force.
9 replies · 6K views · last reply
BadStudent123
Coal miners often find mice in deep mines but rarely find rats; let’s see if we can figure out why. A mouse is roughly 5 cm long by 2 cm wide and has a mass of 30 g; a rat is roughly 20 cm long by 5 cm wide and has a mass of 500 g. Assume that both have a drag coefficient CD ≈ 0.3.
  1. a) Estimate the terminal falling speeds reached by a mouse and a rat, respectively.
  2. b) Assume that mine shafts are deep enough that both the mouse and the rat reach terminal velocity before hitting the bottom. Estimate the magnitude of the maximum force required to stop both the rat and the mouse when they hit the bottom. (Hint: Over what distance will the center of mass travel between the beginning of the collision and when the animal is at rest? What is the acceleration required to bring the animal to rest over this distance? The center of mass can’t travel more than about half the height of an animal, why?)
  3. c) Bones will break if they are subjected to a compressional force per unit area of more than about 1.5 × 108 N/m2. A mouse may have leg bones about 1.5 mm in diameter; for a rat, they might be about twice as thick. Using your estimates from part b), determine if either the mouse or the rat (or both) will suffer broken legs. Is your answer consistent with the observations of the coal miners? Explain.
FD = ρ*v^2*CD*A/2
F = m*a
xcm = (m1*r1 + m2*r2 + ... + mn*rn)/(m1 + m2 + ... + mn)
I did part A without a problem. Simply plugged in values into the FD equation and set it to equal mg for each: mouse and rat. Mouse terminal velocity: 44.27 m/s, Rat terminal velocity: 57.155 m/s.
Part B, I'm not too sure about it. I have no idea what the hints really mean. I actually have no clue how to even start it.
Part C, using Part B's answer, I feel like I can figure it out, however, I'm not entirely sure what area to use, as it states that the leg bone is 1.5 mm in diameter, but says nothing about length, so I'm not sure what to use for surface area.
BadStudent123 said:
  • b) Assume that mine shafts are deep enough that both the mouse and the rat reach terminal velocity before hitting the bottom. Estimate the magnitude of the maximum force required to stop both the rat and the mouse when they hit the bottom. (Hint: Over what distance will the center of mass travel between the beginning of the collision and when the animal is at rest? What is the acceleration required to bring the animal to rest over this distance? The center of mass can’t travel more than about half the height of an animal, why?)
Read the information you are given.
In class, the only center of mass we covered was between two objects, and that the center of mass never travels. Did I miss something?
Bystander said:
Think in terms of "center of mouse."
I'm going to have to google this. Why would the center of the mouse move between collision + at rest? Do you have any resources I can look at?
Read the last sentence in part B. Seems you have to assume the rodents land end-on, since you are given the lengths, not the heights. This is a bit inconsistent: to calculate the drag you had to assume they fall feet first, i.e. in their normal orientation. How, in the dark, they manage to figure out when they're about to hit the ground I'm not sure.
The other doubtful thing about the hint is that by the time the part of the animal that had been the mass centre hits ground level it would be in a fairly bad way. In practice, it would be a question of absorbing the shock over the distance by which they can extend/draw up their legs, but we have no info on this.
My impression was that one could/should "assume a cylindrical mouse/rat" for the impact.
A single object also has a center of mass (How could it not?).
Take a ball. Or a brick.
A ball (or brick) has mass and a center of mass. If you drop the ball (or brick), the center of mass moves with the ball (or brick). (How could it not?)
Maybe. Is there some particular wording that suggests that to you?
