Drop a ball - where does the energy go?
  • Context: High School
  • Thread starter Thread starter oneamp
    Ball Drop Energy
When a bowling ball is dropped, its potential energy transforms into various forms of energy upon impact with the dirt. Initially, some energy is converted into kinetic energy, causing displacement of dirt, while a significant portion ultimately dissipates as heat due to friction. The energy also contributes to sound production and plastic deformation of the impacted material, which stores energy in the form of induced stresses. Over time, all energy transitions to heat, confirming the principle of energy conservation.
  • Understanding of potential and kinetic energy
  • Familiarity with energy transformation principles
  • Basic knowledge of sound energy and heat dissipation
  • Concept of plastic deformation in materials
  • Research the laws of thermodynamics and energy conservation
  • Explore the concept of plastic deformation in materials science
  • Learn about sound energy production and its measurement
  • Investigate methods for starting fires using friction and heat generation
Physics students, materials scientists, and anyone interested in understanding energy transformations and their practical applications in real-world scenarios.
oneamp
Hi -
If I lift a bowling ball in the air, so that it has potential energy, then drop it on the dirt, it makes a sound and a dent. Where did all the energy go? It did not all go to sound, since there's a dent, right? A small bit went to heat... what else?
Thanks
All of it goes to heat, after a while.
The bit that went to heat aint small. Do the following experiment. Ask someone to hold a piece of paper up in the air for you and Bang two pieces of steel together making sure the paper is caught in between them. There should be a burnt spot on the paper afterwards.
Thanks
That's interesting, dauto. If I'm lost in Alaska and about to freeze, and find two hammers and some paper, is it possible that I could start a fire to save my life?
oneamp said:
Hi -
Thanks
Initially some energy goes into the kinetic energy of the little pieces of dirt that are moved away to make that 'dent'. Of course, all of those eventually (very quickly) stop because of friction- which is the same as saying the energy becomes heat energy. (In the long scale 'eventually' all energy becomes heat.)
Unlikely. The paper burns but you don't get a flame that way. The heat dissipates to quickly
Hmmm... What if you lightly soaked the paper in alcohol first? Anyone want to give that a try?
Nah, you do it ... I'm drinking my alcohol :smile:
As mentioned by dauto the heat dissipates very fast, I don't think alcohol will be effective since the temperature will go below the flash point even before oxygen is supplied.
Well, we won't really know until some idiot tries it, right?
Maybe I'll give it a shot tomorrow...
Heat is not the only energy transformation. The dent means plastic deformation, so the breaking or tensing material. So energy gets stored in material induced stresses and get's absorbed by the breaking of chemical or physical bonds. The plastic deformation energy is not all transformable to heat and is very material dependent.
  • · Replies 60 ·
  • · Replies 51 ·
