Drop a bowling ball through the middle of the earth
The discussion centers on the hypothetical scenarios involving a bowling ball and various physics-related questions. Dropping a bowling ball through a hole from the North Pole to the South Pole would result in simple harmonic motion, meaning it would oscillate back and forth rather than exit the hole. When comparing the drop of a bowling ball from 10 feet with a bullet fired parallel to the horizon, the bullet would hit the ground first due to its horizontal velocity. Additionally, spinning the Earth five times faster would not significantly increase gravity, as gravity is a constant force dependent on mass and distance from the center of the Earth.
  • Understanding of basic physics principles, particularly gravity and motion.
  • Familiarity with concepts of simple harmonic motion.
  • Knowledge of projectile motion and its effects.
  • Basic understanding of Earth's rotation and gravitational forces.
  • Research the principles of simple harmonic motion in physics.
  • Study projectile motion and its calculations in various angles.
  • Explore the effects of rotational speed on gravitational forces.
  • Investigate the implications of gravity in different hypothetical scenarios.
Students of physics, educators teaching motion and gravity concepts, and anyone interested in theoretical physics discussions.
windrar
1. What would happen if you drill a hole that ran from the North pole to the South pole and then drop a bowling ball into the hole?
2. If you fire one bullet straight up (90 degrees from horizon) and one bullet at 45 degrees angle to the horizon which one hits the ground first?
3. If you spin Earth 5 times faster than its present once a day rotation, would gravity significantly increase?
4. If you drop a bowling ball from 10 feet up and simultaneously fire a bullet parallel to the horizon which would hit the ground first?
What are your thoughts on these questions?
ans1:the ball would undergo simple harmonic motion i.e(it would not appear at the other end)
ans 2:the bullet fired 45 degrees to horizon would reach first
ans 3:no it would not affect gravity in any way
ans 4:this question seems baseless,please explain it better!
1. The bowling ball would melt first? Depends. Is there a bowler attached to it?
