DSP - Differential Equation for linear system H
The discussion revolves around finding a differential equation for a linear system characterized by the impulse response h(t) = e-2t. Participants explore the relationship between the impulse response, the Laplace transform, and the system's output in response to various inputs. The conversation includes technical reasoning and attempts to clarify the steps needed to derive the desired differential equation.
  • Seán seeks guidance on deriving a differential equation from the impulse response h(t) = e-2t.
  • Some participants suggest transforming the impulse response into the frequency domain using the Laplace transform, leading to the transfer function H(s).
  • There is confusion regarding the necessity of the input's Laplace transform, with some arguing that the relationship should be general rather than specific to a particular input.
  • Participants discuss the implications of using δ(t) as the input and how it relates to the output and the transfer function.
  • Seán expresses uncertainty about the steps to take after obtaining the Laplace transform of the impulse response.
  • There is a clarification that the relationship between the output Y(s) and input X(s) is defined by Y(s) = H(s)X(s), which should hold for any input x(t).
  • Some participants emphasize that X(s) should not be arbitrarily set to 1, as it represents a general input function.
  • There is a suggestion to use cross-multiplication to derive the differential equation from the algebraic relationship in the frequency domain.
Participants generally agree on the need to derive a differential equation relating the input and output through the transfer function. However, there is disagreement on the specifics of how to approach the problem, particularly regarding the treatment of the input and the use of Laplace transforms.
Participants express uncertainty about the correct application of Laplace transforms and the implications of using specific inputs versus general forms. The discussion reflects various assumptions about the nature of the input and its relationship to the system's output.
  • #31
SMOF said:
The sY(s) is the is the first derivative y'(t)
No worries, it is nearly 3am here, and I need some sleep!
Thanks.
Seán
Spot-on! Now, write out the whole equation.
If you're interested, your equation has of course implicit in it an initial condition, although it's immaterial as far as deriving the equation itself, so you don't have to be concerned about it, but if you're interested I can show you how elegantly Laplace takes care of that too.
I'm on MST which is 3 hrs behind you. Unless you get back by around 5 a.m. I'm afraid you won't be hearing from me again until around 1 pm your time. I stay up late & get up late, privilege of being retired!
  • #32
So, if I have it right, it should be
y'(t) + 2y(t) = x(t)?
Yea, that would be great! I really want to learn as much as I can!
And again, thanks so much for all your help. Hopefully (if I finally have it right) I will be able to do it myself.
Seán
  • #33
Good!
Question: have you had differential equations? Like, could you solve this one, for example if x(t) = 0 or x(t) = sin(wt)?
Also: have you had a course in electrical circuits?
  • #34
Hello,
Well, differentiating a constant is zero, but I am not sure of that holds for 0. And differentiating sin(wt) would be cos(wt).
I have done a course in electrical circuits, but it is all very rusty, and very much from a hands on point of view.
Seán
  • #35
SMOF said:
Hello,
Seán
d/dt{sin(wt)} = wcos(wt), not just cos(wt).
Well, that's irrelevant. You don't seem to have the background for me to go into this any further, except to say that your H(s) is that of an electrical R-C network, with R going from x to y, and C going from y to "ground" ()zero volts).
If you applied an impule to this network, the capacitor voltage would respond with a voltage change of exp(-2t), adding that voltage to whatever was on C before the impulse came along, So the initial condition is just the voltage on the capacitor before the impulse came along.
It seems to me you're taking a course out of sequence. To fully appreciate the whole frequency-domain business you need to have taken at least a couple of weeks of differential equations. The widely used textbook, Calculus by Thomas, has a good section for that. I would not try to cover all that's in there; concentrate on linear equations with constant coefficients.
Good luck to you!
  • #36
Well, the online reference I used to make sure said d/dt sin x = cos x.
So, I was taking x = wt.
Anyway, that is neither here nor there. Again, thank you for all your help, and I will check out that book you mentioned.
Seán
  • #37
Seán
d/dt{sinwt) = wcos(wt)
d/d(wt){sin(wt)} = cos(wt)
Your equation differentiates wrt to t, not wt.
  • #38
Seán[/QUOTE
d(dt{sin(wt)} = wcos(wt)
You're differentiating with respect to t, not wt.
Cheers!
  • #39
Grand, I'm with you now.
Seán
  • #40
Hello,
Rather than start another topic, since this question is related to this tread, I thought I would just tack it on here.
We were asked to "Derive a formula for the output signal y as a function of t". I think I have done this correctly, but would be very grateful if someone could cast an eye over my work, in case I have done something silly ...or, just completely wrong. I have attached a pdf.
Many thanks.
  • #41
I wouldn't use t as both the function argument of y and the variable of integration. Your answer looks otherwise correct.
[itex]sY(s) -y0 + 2Y = X(s)[/itex]
[itex]Y(s) = X(s)/(s +2) + y_{0}/(s +2)[/itex]
The Laplace transform is linear, so we may treat the terms separately:
[itex]Y_{1}(s) + Y_{2}(s) \leftrightarrow y_{1}(t) + y_{2}(t)[/itex]
[itex]Y_{1}(s) = X(s)/(s +2)[/itex]
[itex]h_{1}(t) = e^{-2t}[/itex]
The output of the system with impulse response h1(t) can be expressed by convolution.
[itex]y_{1}(t) = (x * h_{1})(t) = \int _{0} ^{\infty} x(\tau)e^{-2(t- \tau)} d\tau = e^{-2t} \int _{0} ^{\infty} x(\tau)e^{2 \tau} d\tau[/itex]
the second term:
[itex]Y_{2}(s) = y_{0}/(s +2)[/itex]
[itex]y_{0}/(s +2) \leftrightarrow y_{0}e^{-2t}[/itex]
solution:
[itex]y(t) = y_{1}(t) + y_{2}(t) = e^{-2t} \int _{0} ^{\infty} x(\tau)e^{2 \tau} d\tau + y_{0}e^{-2t} = e^{-2t} \left( \int _{0} ^{\infty} x(\tau)e^{2 \tau} d\tau + y_{0}\right)[/itex]
  • #42
the second term:
solution:
You know the old song "If you want your boomerang to come back, well first you've got to throw it"?
If you want y(t) you must first have an x(t). What is your input time function? Is it an impulse δ(t), a step function U(t), a ramp kt, or ?
  • #43
If you want a general expression for any x(t), then
y(t) = L-1{(X(s)/(s+2) + y(0+)/(s+2)}
= L-1{X(s)/(s+2)} + y(0+)e-2t
For example, if x(t) = U(t), X(s) = 1/s and
y(t) = L-1{1/s(s+2)} + y(0+)e-2t
= (1/2)(1 - e-2t) + y(0+)e-2t.
  • #44
Oh, also - if you're going to use convolution, why bring in the frequency domain at all?
The nice thing about Laplace is it avoids the screwy convolution integrals. Of course, a good table of transforms is required.
  • #45
The frequency domain was used to obtain impulse response function h1(t), which was necessary for the convolution to be used. If you are able to convert time domain differential equations directly into time domain impulse response functions, please show me how.
Anyway. I understood the task to be finding a general time domain expression for y(t). I chose a different method so the result would be checked by a different method.
  • #46
Hello.
This is cool, thanks for all the replies. It is cool to see how things can be dealt with from different positions.
Seán
  • · Replies 16 ·
