Dynamics Question using nonconstant acceleration
A particle with an initial speed of 27 m/s experiences a deceleration of a = -6t m/s². The time taken for the particle to stop is calculated to be 3 seconds using integration of acceleration. To find the distance traveled before stopping, the integration of velocity with respect to time is suggested, leading to the equation s = -t³ + 27t. The discussion emphasizes the importance of recognizing that acceleration is not constant, which complicates the use of standard formulas. The participants also note the simplicity of the solution despite initial confusion.
gatrhumpy
A particle has an initial speed of 27 m/s. If it experiences a deceleration of a = -(6t) m/s^2, where t is in seconds, determine the distance traveled before it stops.
a = dv/dt
v = ds/dt
ads = vdv (not independent from the above two equations)
What I know: v(0) = initial speed = 27 m/s
v = final speed = 0 m/s
t(0) = initial time = 0 seconds (assumption)
s(0) = initial displacement = 0 meters (assumption)
I used a = dv/dt and integrated to find the time for the particle to stop. I found it this way:
a = dv/dt = (-6t). dv = (-6t)dt. Lower limit for v(0) = 27, upper limit for v = 0. Lower limit for t(0) = 0, upper limit for t = t. Integrating dv = (-6t)dt, I get -v(0) = -3t^2 --> t = 3 seconds. This is the time it takes the particle to stop.
However it asks for the distance to stop, and I have no idea how to get it. I know I can't use constant acceleration formulas because the acceleration is a function of time. I tried using ads = vdv as that is independent of time, but the acceleration a is dependent on time as a = (-6t) m/s^2
In your problem statement you state a constant decelaration of 6 m/s^2
Then you go on with: a = dv/dt = (-6t), which is the correct defintion
Integration produces : v = -3*t^2+v0. You got the integration idea very right.
t = 3 sec.
So, continue with: v = ds/dt in a similar way.
v = ds/dt integration gives: s = (-3/3)*t^3+v0*t+s0
You can solve this for t= 3 sec.
Thanks man.
I'm 're-learning' dynamics for my FIT exam in October. Funny how the simplest solution is right there in front of you and yet, nothing. :)
Why din you try 2nd Order Differential Equation? differentiate twice will induce many unnecessary constants.
Probably could have, but haven't reviewed DEs yet. :)
