E and B Fields of Monochromatic Plane Waves
5 replies · 3K views
roam
560 nm light is collimated and passes as a parallel beam in a direction perpendicular to the ##x+y+z=0## plane. It is polarized parallel to the ##(y-z)## plane. Treating it as a plane wave, what are the real E and B fields?
Intensity of the beam is ##1 \ mW/cm^2##. Make your expressions for the fields as numerical as possible.
##E(r, t) = E_0 \ cos (k.r - \omega t) \hat{n}##
##B(r,t) = \frac{1}{c} E_0 \ cos (k.r - \omega t) (\hat{k} \times \hat{n})##
Where ##k## is the propagation/wave vector, and ##\hat{n}## is the direction of popularization.
##k=\frac{\omega}{\lambda f}=\frac{\omega}{c}= \frac{2 \pi}{\lambda}##
Using the following relationship, I used the given intensity to work out the amplitude:
##I=\frac{1}{2} c \epsilon_0 E_0^2 \implies E_0 = \sqrt{\frac{2I}{c \epsilon_0}} = 7.685 \times 10^{-10} \ V/m##
So, to find ##k.r## and ##k \times \hat{n}##, I need the equation for a plane perpendicular to the ##x+y+z=0## plane. But how can I find this equation when there are infinitely many such vectors? :confused:
For instance the wave vector is ##k= \omega/c \ \hat{k}##, where ##\hat{k}## is a unit vector in the direction of the vector perpendicular to the ##x+y+z=0## plane. I also need that in order to work out the cross product ##\hat{k} \times \hat{n}## for the B field.
As for the polarization ##\hat{n}## (parallel to y-z plane), would the unit vector be ##\hat{n} = \frac{\hat{y}+\hat{z}}{\sqrt{2}}##? Or does the plus sign need to be changed to a minus? Any explanation would be greatly appreciated.
on Phys.org
No, there is only one unit vector perpendicular to a given plane. Given ##\lambda## and the unit vector associated with the propagation, ##k## will be uniquely defined.
After finding such unit vector, use the fact that ##k## must be perpendicular to ##n##.
Yes, we need to have ##\hat{n} . k = 0##. But what is the actual expression for this unit vector (that is perpendicular to ##x+y+z=0##)?
(I believe it should be of the form ##\hat{k}=(a\hat{x}+b\hat{y}+c\hat{z})/\sqrt{3}##, I then need to write ##k=\frac{2 \pi}{\lambda} \hat{k}##).
And what expression do you use for ##\hat{n}##? Is it ##(\hat{y} + \hat{z})/\sqrt{2}## or ##(\hat{y} - \hat{z})/\sqrt{2}## ? :confused:
Note that you can view the expression ## x+y+z=0## as a dot product between two vectors which are perpendicular to each other.
Another alternative will be apparent if you are more familiar with the use of gradient ##\nabla## to find a normal vector w.r.t. to a surface.
Let's first solve the vector ##k##, after that it should be easy to find the correct ##\hat{n}##.
How should I use the gradient ##\nabla## here? What are we differentiating?
