E(X) and Var(X) for Normal Dist.
  • Thread starter Thread starter ArcanaNoir
    Normal
9 replies · 2K views
ArcanaNoir
Let X be normally distributed with the paremeters 0 and σ2. Find:
a. E(X2)
b. E(aX2+b)
E(X) = [itex]\int_{-\infty}^{\infty} \! xf(x) \mathrm{d} x[/itex]
E(X2) = [itex]\int_{-\infty}^{\infty} \! x^2f(x) \mathrm{d} x[/itex]
E(aX+b) = [itex]aE(X)+b[/itex]
The normal distribution with paremeters 0 and σ2 = [itex]( \frac{1}{\sigma \sqrt{2 \pi }}) e^{ \frac{-x^2}{2 \sigma ^2}}[/itex]
a. [itex]E(X^2)= \frac{1}{ \sigma \sqrt{2 \pi }} \int_{-\infty}^{\infty} \! x^2e^{ \frac{-x^2}{2 \sigma ^2}} \mathrm{d} x[/itex]
I don't knowhow to solve this integral. I think there might some tricks involved using the fact that this is a distribution function.
b. I just need to find E(X) which I start by setting up: [itex]E(X)= \frac{1}{ \sigma \sqrt{2 \pi }} \int_{-\infty}^{\infty} \! xe^{ \frac{-x^2}{2 \sigma ^2}} \mathrm{d} x[/itex]
I don't know how to solve this integral either.
I also don't know how to solve the simpler integral [itex]\int e^{ \frac{-x^2}{2 \sigma ^2}} \mathrm{d} x[/itex]
Try integration by parts with
[tex]u = x,\, dv = xe^{-\frac {x^2}{2\sigma^2}}[/tex]
Then you should be able to use the fact that the first moment is 0 and the fact that the normal distribution function is a distribution function.
Hi Arcana! :smile:
The integral [itex]\int_{-\infty}^x e^{-t^2}dt[/itex] is proven to be unsolvable (with standard functions).
That's why they introduced a new function to deal with this (the cdf of the standard normal distribution):
[tex]\Phi(x) = {1 \over \sqrt{2\pi}} \int_{-\infty}^x e^{-t^2 \over 2}dt[/tex]
[itex]\Phi[/itex] has the property that [itex]\Phi(+\infty) = 1[/itex], but to find any regular function value it needs to be approximated numerically.
The trick for your problem is to use partial integration (as LCKurtz suggested).
Either you can solve directly, or you can reduce your formula to something like [itex]\int_{-\infty}^{+\infty} e^{-t^2 \over 2}dt[/itex] and use that it is [itex]\sqrt{2\pi}[/itex].
a. E(X2)
b. E(aX2+b)
Don't you mean [itex]E(a X^2 + b) = a E(X^2) + b[/itex]? I am surprised that you have not seen the standard result that [itex]\mbox{Var}(X) = E(X^2) - (EX)^2[/itex], which is true for _any_ random variable having finite mean and variance. It ought to be in your textbook or course notes.
RGV
I don't remember why I thought finding E(X) was going to help. As for E(X2), here is my attempt. And I'm sure I'm breaking tons of rules here.
[tex]E(X^2) = \frac{1}{ \sigma \sqrt{2 \pi }} \int_{-\infty}^{\infty} \! x^2e^{ \frac{-x^2}{2 \sigma ^2}} \mathrm{d} x[/tex]
[tex]u=x^2[/tex] [tex]\mathrm{d} u=2x \mathrm{d} v[/tex] [tex]v= \sqrt{2\pi }[/tex] [tex]dv= e^{-\frac {x^2}{2\sigma^2}} \mathrm{d} x[/tex]
[tex]\frac{1}{ \sigma \sqrt{2 \pi }} \int_{-\infty}^{\infty} \! x^2e^{ \frac{-x^2}{2 \sigma ^2}} \mathrm{d} x =[/tex]
[tex] \frac{1}{ \sigma \sqrt{2 \pi }}( x^2 \sqrt{2\pi } ^{-\infty }_{\infty } - \sqrt{2\pi } \int_{-\infty}^{\infty} \! 2x \mathrm{d} x )[/tex]
Am I messing it up? I don't think I'm on the right track.
Let's see.
We want to apply partial integration, which is:
[tex]\int u dv = u v - \int v du[/tex]
I hope you don't mind that I point out a few rules that you are breaking. :shy:
Perhaps we can fix that.
[tex]u=x^2[/tex][tex]\mathrm{d} u=2x \mathrm{d} v[/tex]
With your choice for u this should be: [itex]\mathrm{d} u=2x \mathrm{d} x[/itex]
With this choice for v, we would get: [itex]dv = 0[/itex].
That can't be right. :confused:
With this choice for dv, I don't see how you can figure out v, since this expression does not have an anti-derivative (expressed in standard functions).
There should be a vertical line in there, and the limits should be switched around.
But let's take care of that when the rest is in order.
Only a little bit.
It needs to be tweaked a bit to get on the right track.
I recommend using:
[tex]u = x[/tex][tex]dv = x e^{-\frac {x^2}{2\sigma^2}} \mathrm{d} x[/tex]
Of course this means that you have to integrate dv to find v...
Hooray! The problem is solved! Thanks team :)
it mostly went down in chat, lots of integrating with substitutions and by parts.
