lsume said:
Yes! As you know KE = 1/2 m v^2. So let's make an assumption about the mass of this hypothetical asteroid. Let us assume that the density of the asteroid is 490 pounds per cubic ft. which is an average density of steel. One common misconception is that an astronaut appearing to float in space is weightless. Since generally, the astronaut is in a geosynchronous orbit and his centripetal force cancels the gravitational force exerted by the earth. The Earth is still exerting a force on the astronaut. Now for our asteroid, assume that the asteroid is 300' in diameter and it's shape mirrors a sphere. The volume of this spherical asteroid is (4/3) pi r^3 = 14,130,000 cubic ft. with a mass of
((14,130,000)(490)/32.174) = 215,195,499 slugs
So about 3 x 10
9 kg. Note that SI units are preferred internationally.
If this asteroid is going to hit Earth then logically it's under the gravitational pull of the earth. The force exerted is inversely proportional to the distance from the center of gravity squared but the acceleration component is always present albeit very weak at great distance but present none the less. Make your own assumption about the speed at impact but rest assured it will be a very high speed.
Assuming your desired conclusion is not a good approach. Make no assumptions about the final speed or what constitutes "very high speed". Very high compared to what?
I am not going to give a velocity which implies direction I am assuming a direct hit normal to the earth. As I recall, the escape velocity from Earth is 7 miles per second, and for no reason I'll use that scaler for the kinetic energy calc. ( 215,195,499 ) (0.5 ) (360,960 )^2 = ONE GREAT BIG NUMBER which would blow away planet earth.
About 2 x 10
17 Joules. You cannot conclude that because the number looks big to you that that it will "blow away planet earth". You haven't presented an argument to support an actual required amount of energy to accomplish this feat.
You might start by determining the gravitational binding energy of the Earth itself. Ultimately it's gravity that's holding the planet together. Assuming approximately uniform density for the Earth with mass M
e and radius R
e,
##U = \frac{3 G {M_e}^2}{5 R_e}##
Which is on the order of 2 x 10
32 Joules, which is about 15 orders of magnitude larger than your estimated impact energy.
This is not to say that the results of such an impact would be insignificant to us surface dwellers, but it would not be of concern to the Earth's overall integrity as a planet.
Now, as to the tangential velocity of Earth and the orbital velocity of Earth around the sun, let's assume they are working together for a worst case scenario. The circumference of Earth is 24,901 miles and at 1 revolution every 24 hours the tangential velocity at the equator would be 1,521 ft./sec. Assume the average distance that the Earth is from the sun is 93 million miles and rather than calculating based on the elliptical orbit just use a circular orbit. So, based on these assumptions, the Earth travels ( pi ) D every 365 days. The speed of orbit would then be 9.25 miles per second. Your point was well taken. If we couple the tangential and orbital scalers or we don't couple these scalers, the orbital speed is more than enough to blow away planet earth. Thanks for the heads up Gneill. I never did this simple calc before this am.
Again, you can't leap to the conclusion that the Earth will be "blown away" without running the actual numbers. The speed of the Earth's surface due to its rotation is dwarfed by the orbital speed of the Earth (about half a km per second versus about 30 km per second), so ignoring the rotational contribution the worst case scenario would add 30 km per second to the impact velocity used above. Let's call it 41 km/sec in total. That yields a kinetic energy of about 2.5 x 10
18 Joules. Still a drop in the bucket compared to Earth's gravitational binding energy.
Running these sorts of calculations for "what if" scenarios is excellent practice. I applaud your enthusiasm and encourage you to keep at it. They help to temper our tendency to leap to unwarranted conclusions when numbers seem large (but turn out not to be when placed in context) and help to hone our intuitions and instincts about likely outcomes.
Edit: I made a couple of calculation errors (futzed the conversion of the diameter of the proposed iron sphere). The mass of the 300 foot diameter sphere would be about 2.1 x 10
7 kg, not the 3 x 10
9 kg that I wrote. So the impact KE at escape speed would be even smaller than I wrote, about 1.3 x 10
15 Joules rather than 2 x 10
17 Joules. For the 41 km/s case it would be about 2 x 10
16 Joules. Sorry for any confusion this might have caused.
