Discovering Earth's Escape Velocity: The Ultimate Measure of Gravity's Power
The Earth's escape velocity is approximately 11.2 km/s, which is the speed required to break free from Earth's gravitational pull without any further propulsion. This concept is independent of the mass of the object attempting to escape; rather, it relies solely on the speed achieved. Jumping off the ground does not equate to escaping Earth's gravity, as the force of gravity will always pull the jumper back down unless a continuous force, such as that provided by a rocket, is applied. The discussion emphasizes the distinction between escape velocity and the forces required to achieve upward motion.
  • Understanding of gravitational force and its effects
  • Basic knowledge of physics concepts such as velocity and acceleration
  • Familiarity with the concept of escape velocity
  • Knowledge of rocket propulsion principles
  • Research the formula for escape velocity and its derivation
  • Explore the physics of gravitational fields and their variations with distance
  • Study the mechanics of rocket propulsion and how it enables escape from planetary bodies
  • Investigate the differences in escape velocity for various celestial bodies, such as asteroids and comets
Astronomy enthusiasts, physics students, aerospace engineers, and anyone interested in understanding gravitational dynamics and escape mechanisms from planetary surfaces.
Neon
The Earth's escape velocity is in km per s. But i can jump off the ground! i know but the estimate for the Earth's escape velocity in for an object of what mass? Defintely more than a ton.
But you're not escaping. You'll come right back down.
The escape velocity is independent of mass.
if i jumped and the Earth gravity disappear or i have that force constantly pushing me up with a typical jump force, i will be in space right?Technically I used enough force to oppose the Earth's gravity and go the opposite direction. So... any referances?
The only thing pulling you back down is the Earth's gravity. So if that gravity "disappeared" you would keep going. (Not a particularly realistic scenario. What's your point?)
To jump off the ground, you just need a net upward force. Easily achievable. So what?
References for what?
"Escape velocity" doesn't mean "the speed you need to be able to jump up from the ground". It means "the speed you need to be able to escape to infinity, starting from the Earth's surface, with no further force applied". ("Escape to infinity" means "get so far away from the Earth that its gravity would be negligible". The Earth's gravity is certainly not negligible a few feet off the ground--as Doc Al pointed out, it will pull you right back down when you jump.
The Earth's gravity can't disappear; that would violate the laws of physics. It's pointless to ask what would happen if the laws of physics were violated; there's no way to answer the question since the only means we have for predicting what would happen is to apply the laws of physics.
If you have a force constantly pushing on you, yes, you can get to space; that's what rockets do (their engines are constantly pushing on them until they get into orbit). But the concept of escape velocity doesn't apply in that case, because there's a continuous force being applied; as I said above, escape velocity is the speed you would need to move to escape to infinity with no further force applied.
Shoot a gun straight up. If the bullet will eventually fall back to the earth, then the muzzle velocity of the bullet was less than escape velocity. If the bullet never falls back, then the muzzle velocity was greater than or equal to escape velocity. The mass of the bullet doesn't matter, just the speed (although it will of course take a more powerful to gun to fire a heavier bullet at the same speed).
In practice, no traditional gun is capable of firing bullets at speeds greater than escape velocity, which is why we use rockets to launch spacecraft instead.
If you were on the surface of a small asteroid or comet you could escape by jumping. For example, comet 67P/Churyumov has an escape velocity of 1 m/s.
Ok i get the escape to infinity part so instantly accelerate to the speed and stop WILL escape Earth right?
What about the area where the gravity reaches out that is significant enough to be measure? like the hill sphere of Earth and black hole are vastly different. So outside the event horizon would be and low in escape velocity as I need to move through less of its gravity.
What event horizon?
I think you should take a moment to collect your thoughts, because your question seems to be shifting as people try and answer it.
I am asking if the Earth's gravity gets weaker faster, would escape be easier?
Are you familiar with the equation for g (the acceleration due to Earth's gravity) as a function of radius from the center of the Earth? You should be able to calculate this for yourself if you've seen the equation. If you haven't seen it, you can use wikipedia to find it. Let us know if you need help finding it. :smile:
And BTW, we do not address questions that propose breaking the rules for physics here. We address questions about how the real physics works. Does that make sense?
Ok i get it now thanks everyone!
9K
  • · Replies 43 ·
  • · Replies 31 ·
