Easy circuit question but i get the wrong answer for PD
  • Thread starter Thread starter mr_coffee
    Circuit Pd
The discussion centers on calculating the potential difference across a car battery with a 12 V emf and an internal resistance of 0.050 ohms while charging with a current of 60 A. The correct potential difference across the terminals during charging is 15 V, calculated by adding the voltage drop across the internal resistance (3 V) to the emf. When the battery discharges while supplying 60 A to a starter motor, the terminal voltage drops to 9 V due to the same internal resistance. The initial calculation of 9 V during charging was incorrect.
  • Understanding of Ohm's Law
  • Familiarity with the concept of electromotive force (emf)
  • Knowledge of internal resistance in batteries
  • Basic circuit analysis techniques
  • Study the effects of internal resistance on battery performance
  • Learn about the charging and discharging characteristics of lead-acid batteries
  • Explore advanced circuit analysis techniques using Kirchhoff's laws
  • Investigate the implications of voltage drops in series circuits
Electrical engineers, physics students, and anyone involved in battery technology or circuit design will benefit from this discussion.
mr_coffee
Hello everyone! I am stuck on this simple problem...
A car battery with a 12 V emf and an internal resistance of 0.050 is being charged with a current of 60 A.
(a) What is the potential difference V across its terminals?
wrong check mark V
(b) What is the rate Pr of energy dissipation inside the battery?
W
(c) At what rate is electrical energy being converted to chemical energy?
W
(d) When the battery is used to supply 60 A to the starter motor, what is V?
V
(e) What is Pr in this case?
W
I found the V = 9V;
I drew the simple circuit then Used
Vb-Va = E-Ir;
V = 12v -60*.050 = 9V, but it was wrong, any ideas? thanks
pd = 12V
correct
pd = 12V
correct me if i am wrong
I found the V = 9V;
Vb-Va = E-Ir;
The car battery can be imagined as an ideal voltage source of emf 12 V and the internal resitance r=0.050 ohm connected in series. See the picture. A and B are the terminals of the battery, and X is the virtual junction of the virtual ideal source with the internal resistance.
The carging current flows into the battery to supply positive charges onto the positive electrode. It causes a potential drop of 0.05 * 60 = 3 V across the internal resistance. The potential drops along the direction of the current. So B is more positive than X. X is more positive than A. So the net potential difference across the terminals A, B of the real battery is 12+3=15 V during the process of charging.
Your formula is true when the battery supplies current to the starter motor. The direction of this current is reverse with respect to the charging current and the potential drops 3 V from X to B inside the battery. The terminal voltage is 9 V during discharge.
ehild
  • · Replies 34 ·
  • · Replies 22 ·
  • · Replies 20 ·
