Easy speasy but i dont get it.
  • Thread starter Thread starter shimmeringlight
The problem involves determining the standard form equation of a hyperbola given its center, a focus, and the length of the conjugate axis. The original poster expresses confusion regarding the relationship between the parameters of the hyperbola and the equations involved.
  • Mixed
  • The original poster attempts to apply the standard form of a hyperbola but questions the values of a and b based on the given information. Some participants raise concerns about the correct relationship between c, a, and b, with conflicting references to the equations used for hyperbolas and ellipses.
Participants are exploring different interpretations of the equations related to hyperbolas and ellipses. Some guidance has been offered regarding the standard form of the hyperbola, but there is no explicit consensus on the correct approach or resolution to the problem.
There is confusion regarding the definitions and relationships of the parameters involved in hyperbolas, particularly the use of c² = a² + b² versus c² = a² - b². The original poster also notes that the mention of vertices has contributed to their misunderstanding.
shimmeringlight
okay, so math
it says...
Determine an equation in standard from for each hyperbola...
centre (-2,1), one focus (-4,1), length of conjugate axis 4
what i figured out... but its wrong... because i can't figure out the answer!
(x+2)^2 - (y-1)^2 = 1
a^2_____[/color]b^2
conjugate axis is 4 so co-ordinates for the co-vertices or vertices should be
(-2,3), (-2,-1)
so then to find find the a or b value... i use
c^2=a^2+b^2
2^2=a^2+2^2
but 4-4=0... and that's impossible? i got stuck here...
help please... thank you in advance.
c^2=a^2+b^2
I always thought that in these problems, you would use c^2=a^2-b^2...Could someone check that?
i checked it but my book says c^2=a^2+b^2 unless the book is wrong... but I've done other problems and its worked out... I am just stuck on this one question. :frown:
\frac {(x+2)^2}{a^2}- \frac{(y-1)^2}{b^2} =1 your first equation looks fine.
I needed to review conjuage axis as well as transverse axis as it pertains to hyperbolae.
You may want to review that page too, as it may offer some clues on how to solve this problem.
They also confirm your relation c^2=a^2+b^2
Another good hyperbola reference from mathworld.
Moose is corret, c^2 = a^2 - b^2. You will have to post the orginal problem for me to help you anymore, I do not really remember ellipses well.
For reference, standard form: \frac{x-h^2}{a^2} - \frac{y-k^2}{b^2} = 1, where the ellipse is centered at (h, k).
ok, i figured it out. thx
That equation is great for an ellipse, this is a hyperbola question. :wink:
Hahaha :-p
I was wondering why I could not do much of the problem, I think mentioning two vertices threw me off the hyperbola, I always associate them with ellipses.
  • · Replies 21 ·
