Easy tangent line problem but I don't know how to approach it
To determine if the line L is tangent to the function f(x) = 4x^2 - x^3 at x = 3, the first step involves equating the two equations to find their intersection points, resulting in the polynomial 0 = x^3 - 4x^2 - 3x + 18. Synthetic division reveals that (x - 3) is a factor, leading to the roots x = 3 and x = -2, indicating that the line intersects the curve at x = 3. However, to confirm tangency, it is essential to check that the derivatives of both functions are equal at this point. This means calculating the derivative of f(x) and ensuring it matches the slope of line L at x = 3, which is necessary to establish that they are indeed tangent.
Fiorella
Let f be the funtion given by f(x) = 4x^2 - x^3 , let L be the line y = 18 - 3x, where L is tangent to the graph of f.
Show that L is the tangent to the graph of y= f(x) at the point x = 3.
I'm equaling both graphs like this:
4x^2 - x^3 = 18 - 3x
and then I isolate everything to the right:
But I don't know how to factor this...am I in the right track to prove that this line is tangent to the function?
Since you KNOW L is a tangent line, it's a bit easier to equate the derivatives. That just gives you a quadratic equation. Once you do that you still have to check f(x)=y for the two solutions. On the other hand you can factor that expression if you work at it. Review factoring. The only possible factors are (x-a) where a is a divisor of 18. And if (x-a) is a factor then substituting a into the polynomial gives you zero. Once you have a factor divide it out to reduce the degree. And don't forget to check y'=f'(x) for each root. Otherwise it's only a crossing point, not a tangent.
Hint: (x-3) is a factor.
Ok Dick so I did synthetic division and I got:
x^2 - x - 6 (x - 3)
(x + 2) (x - 3) (x - 3)
x = -2 x=3 -----> so this proves that the line L is tangent to f(x) at x = 3?
I know somewhere I have to use derivatives to prove it, but I don't know how :(
x^2 - x - 6 (x - 3)
That doesn't prove they are tangent. It proves the line intersects the curve at x=3. To show they are tangent you also need to show they have the same slope. Show that their derivatives are also equal at x=3.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
