EDTA titration-(Analytical Chem.)
  • Thread starter Thread starter tipton12
    Chem Edta
The discussion centers on the analysis of a mixture of Mn2+, Mg2+, and Zn2+ using EDTA titration. A sample was treated with hydroxylammonium chloride and ammonia buffer, then titrated with EDTA to determine the metal concentrations. The participants calculated the moles of each metal ion based on the volumes and concentrations used in the titration process. Corrections and confirmations were made regarding the calculations for each metal, with final results indicating the amounts of Mg2+, Zn2+, and Mn2+ in the sample. The conversation emphasizes the importance of proper stoichiometric calculations and the reactions involved in displacing metal ions from their complexes.
tipton12
EDTA titration--(Analytical Chem.)
A mixture of Mn2+, Mg2+, and Zn2+ was analyzed as follows: The 25.00mL sample was treated with 0.25g of NH3OHCl (hydroxylammonium chloride)--a reducing agent that maintains manganese in the 2+ state. 10 mL of ammonia buffer (pH10) and a few drops of eriochrome black T indicator and then diluted to 100 mL. It was warmed to 40 degrees (C) and titrated with 39.98 mL of 0.04500 M EDTA to the blue end point. Then 2.5g of NaF was added to displace Mg2+ from its EDTA complex. The liberated EDTA required 10.26 mL of standard 0.02065 M Mn2+ for complete titration. After this second end point was reached, 5 mL of 15 wt% aqueous KCN was added to displace Zn2+ from its EDTA complex. This time the liberated EDTA required 15.47 mL of standard 0.02065 M Mn2+. Calculate the number of milligrams of each metal (Mn2+, Zn2+, and Mg2+) in the 25.00 mL sample of unknown. (note: EDTA reacts 1:1 with metal ions).
--ok, I seriously have no idea where to start. I definitely need a starting point. Am I right to assume since EDTA reacts 1:1, that I do not need to do redox for each metal ion? ---Please help!
Chemistry news on Phys.org
Yes, EDTA reacts with almost all metal ions in 1:1 stoichiometric molar ratio, as it has six donor atoms to bind to metal ions. Multiply all the volumes in mL with their corresponding concentrations in mol/L to convert to their millimoles. This may help you fro the beginning.
I did that already to get:
(10.26mL)(0.02065mmol/mL)=0.2112 mmol Mn2+
(15.47mL)(0.02065mmol/mL)=0.3195 mmol Mn2+
Then, I subtracted the two, to get 0.1083mmol Mn2+
I then took that number and multiplied it with the weight:
(.1083mmol Mn2+)(54.938mg/mmol Mn2+)=5.95mg Mn2+
Is this correct for the Mn2+? Or do I need to do something different? When I got to that point, I didn't know where else to go to get the Zn2+ and the Mg2+. Any suggestions?
It seems okay with Mn2+ ion.
In the beginning, you know that
is the total of three ions.
MgF2 precipitate is formed by the action of fluoride to magnesium, if I am not wrong. So one mole of EDTA is released to the medium, and this is treated with the given amount of standard Mg2+ solution.
Zinc ion forms a tetracyanozincate(II) complex, as shown with the formula [Zn(CN)4]2-.
What you need to do is simply write the formation reactions of the compounds I mentioned, and find how many moles of reactants (fluoride or cyanide) is required.
I got 7.035mg Zn2+ , 2.14x10^3 mg Mg2+, and 5.95mg Mn 2+. I hope these values are correct,but if they are not then it is only an error in my math. thanks a lot for all your help! tipton12
I changed my answer last minute to get the actual correct answers:
mmoles Mg2+= (10.26)(.02065M)=.2119
mmoles Zn2+=(15.47mL)(.02065M)=.3195
mmoles Mn2+=1.799-.2119-.3195=1.278
(.2119mmolesMg2+)(24.3051mg/mmole)=5.150mg Mg2+
(.3195mmolesZn2+)(65.392mg/mmole)=20.89mg Zn2+
(1.278mmolesMn2+)(54.9380mg/mmole)=70.21mgMn2+
the 1.799 comes from (39.98mL)(.04500mmoles/mL EDTA)=1.799
