Effect of Faucet Location on Water Discharge from a Tank
The discussion revolves around the effect of faucet location on water discharge from a tank, specifically comparing a faucet positioned at the side near the bottom to one located at the bottom center of the tank. The subject area includes fluid dynamics and the application of Bernoulli's principle.
  • Exploratory, Conceptual clarification
  • The original poster questions whether the solution would change based on the faucet's location, considering the height difference as a potential factor. Some participants affirm the original poster's reasoning about water pressure being uniform in all directions.
The discussion is ongoing, with some participants expressing agreement with the original poster's theory regarding the faucet's location and its effect on water discharge. However, no definitive consensus has been reached, and further exploration of the topic is implied.
The conversation hints at a potential oversight regarding the implications of faucet orientation and pressure dynamics, but no additional constraints or assumptions are explicitly stated.
ultimateceej
This is more of a question:
In class, we solved an example with water leaving a tank from a faucet on the side and near the bottom. The result was v=(2gz)^(1/2)... the Torricelli equation. What I am wondering is if the solution would change if the faucet were located at the bottom center of the tank instead of the side.
Bernoulli Equation
The only change I can think of is the small difference in height between where the faucet was on the side of the tank and the new location on the bottom. That seems a little too simple and convenient, though. Any help is appreciated.
Your theory sounds correct to me! Water pressure pushes equally in all directions so the orientation of the tap on the tank should not matter.
Yes. You are right.
Ok thank you!
  • · Replies 22 ·
