Einstein's Field Equations: Effective Potential Functions
Effective potential functions exist for various solutions to Einstein's field equations, including the Kerr-Newman metrics, which can be derived using Killing fields to obtain first integrals of motion. The term "effective" is used because these potentials resemble classical mechanics' energy terms but do not correspond directly to physical potential energy due to the non-static nature of most spacetimes. While the Schwarzschild geodesic provides a well-documented effective potential, comprehensive resources listing all effective potentials for every solution are lacking. Relevant literature includes sections from MTW and various academic papers that explore these concepts further. Understanding these effective potentials enhances the analysis of particle dynamics in curved spacetime.
novice_hack
I have seen written out in various places (including this forum) the effective potential function that comes from the solutions to the Schwarszschild Geodesic. But I haven't been able to find the effective potential functions for other solutions to Einstein's field equations. Are there effective potential functions for the other solutions? And if so, is there a resource where some or all of them are written out.
Why "effective?"
Most spacetimes aren't static, and therefore can't be described by a potential.
bcrowell said:
Why "effective?"
I can explain why the use of the word "effective". You can treat the quantity \mathcal{L} = \frac{1}{2} g_{\mu \nu} \frac{dx^\mu}{ds} \frac{dx^\nu}{ds} as if it were a Lagrangian in 4-D Newtonian mechanics. Then there are terms that look like "potential energy" and "kinetic energy" terms. They aren't really.
Yes. There is an effective potential for the general family of Kerr-Newman metrics. As long as you have the necessary Killing fields you can get enough first integrals of motion to write down an effective 1D potential for the dynamics of a particle whose worldline respects the symmetries of the Killing fields. It is straightforward but tedious to calculate this effective potential. C.f. section 33.5 of MTW. See also http://arxiv.org/pdf/1103.1807.pdf, http://arxiv.org/pdf/1304.2142v1.pdf, and http://www.roma1.infn.it/teongrav/leonardo/bh/bhcap4.pdf
I do not know of an enumeration of effective potentials for every known solution to the EFEs. Note there are also effective potential methods in PPN.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 18 ·
  • · Replies 57 ·
  • · Replies 186 ·
11K
  • · Replies 16 ·
  • · Replies 0 ·
