Effective Reynolds Number for a swept wing
The discussion focuses on determining the appropriate Reynolds number (Re) to use for analyzing the boundary layer (B.L.) thickness at the trailing edge of a swept flat plate. Three options for calculating Re are presented: Re for the unswept wing, Re normal to the leading edge, and Re parallel to the flow. The consensus indicates that the choice of Re significantly impacts the predicted B.L. thickness, particularly when transitioning from an unswept to a swept configuration. The conversation highlights the complexities introduced by spanwise pressure gradients in swept wings compared to flat plates.
  • Understanding of Reynolds number calculations in fluid dynamics
  • Familiarity with boundary layer theory and its implications on airfoil performance
  • Knowledge of aerodynamic forces acting on wings, including lift (L) and drag (D)
  • Basic principles of incompressible flow and turbulent boundary layers
  • Research the effects of wing sweep on aerodynamic performance and boundary layer characteristics
  • Study the differences in boundary layer behavior between swept wings and flat plates
  • Explore advanced computational fluid dynamics (CFD) tools for simulating boundary layer development
  • Investigate empirical methods for measuring boundary layer thickness in experimental setups
Aerospace engineers, fluid dynamics researchers, and students studying aerodynamics who are interested in the effects of wing geometry on boundary layer behavior and aerodynamic performance.
Murmur79
Suppose we have an infinite straight wing, using a given airfoil. Also, suppose for simplicity the B.L. is completely turbulent, and M<<1 (incompressible fluid).
As we know, the forces per unit length are: L=q⋅c⋅cl, D=q⋅c⋅cd, where cl and cd are the coefficients of the 2D airfoil for the given Re and α.
Now, if we rotate the infinite wing of an angle Λ, we have an infinite swept wing.
The theory says that in this case, the forces per unit length (parallel to leading edge) become: L=q⋅cos2Λ⋅c⋅cl, D=q⋅cos2Λ⋅c⋅cd.
Here is my question:
when looking up the cl and cd for the 2D airfoil, should we use:
.) the Re for the unswept wing: Re=U⋅c/ν
.) the Re normal to leading edge: Re=U⋅cosΛ⋅c/ν
.) the Re parallel to the flow: Re=U⋅(c/cosΛ)/ν
Ok, meanwhile a simpler example came to my mind.
Consider a flat plate of infinite length and chord c at zero incidence. Incompressible flow and 100% turbulent B.L.
In this case, we know that, for example, the thickness of the B.L. at the trailing edge will be δ=f(Re).
Now we rotate the flat plate of angle Λ.
What will the new B.L. thickness be at the trailing edge? What Re does it make sense to use between the 3 options given above?
I'll make a few comments here. First, a swept flat plat behaves very differently than a swept wing. The latter has spanwise pressure gradients. The former does not.
Second, for a wing swept at a fixed ##\Lambda##, do you expect the Reynolds number trends to change whether it (a constant) is included in the Reynolds number or not?
hi bone3ead,
yes, I realized the two cases are different. Let's consider the simpler example of the flat plate. In this case, the spanwise/chordwise gradients should be minimized.
I was wondering, for the experiment described above, which one between the three Re definitions, would give the closest results to the actual B.L. thickness at the trailing edge in the swept flat plate, _in the hypothesis_ that we use the same formula for the B.L. thickness in the two cases (swept/unswept).
I know that using the same formula has no theoretical basis at all, and could (intuitively) only be reasonable if the B.L. characteristics are not much changed, hence the hypothesis of the flat plate which should minimize spanwise effects.
In other words, I'd be curious to know what would happen at the thickness of the B.L. if we sweep a flat plate from 0 to say 45 or 60 degrees, and if there is a new specific Re that can predict the result without changing the formula used for the unswept flat plate.
  • · Replies 17 ·
13K
