Effects of coherence length on optical interference filter
66 replies · 10K views
shiweiliu
I have an optical interference filter that is used to block (reflect) solar light heat between 800nm and 1100nm. That filter is made by using 200 layers of quarter wave high and low index coatings on plastic film. The total thickness of the coating is 25 micrometers or even 50 micrometers.
I was told that interference effect can only happen when the thickness of coating is less than coherence length of light. How can my filter work when the total thickness of interference coating is much larger than the coherence length of solar light that is only about one micrometer?
I can understand locally the adjacent coating layers can still have interference effect but how can the light beam reflected by the top coating layer interfere with light beam reflected by bottom coating layer since the optical path difference between these two beams is far larger than coherence length of solar light?
The coherence length of sunlight is significantly larger than ##1 \mu\text{m}##.
From this reference: Spatial coherence of sunlight... I quote an excerpt (from pg. 98):
So for a solar wavelength of ##0.5 \mu\text{m}## the coherence length ##L_\bot## amounts to ##40 \mu\text{m}##.
  • Skeptical
Oh. I estimated it according to formula: wavelength^2/Delta wavelength. Wavelength is about 500nm and Delta wavelength is about 300nm. It is about one micrometer. Something is wrong in my method?
defining the coherence length L⊥ as the slit separation for which theamplitude of η⊥ decays to 1∕2, we find that L⊥ 80λ fordirect sunshine
It looks like they are defining something that they call for "a coherence length", but I am not sure that is the same as coherence length defined as "the maximum optical path difference to still observe interference".
For unfiltered sunlight the interference would disappear withing 1um or less path difference. Using a narrow bandpass filter (or spectral device) it is possible to get interference with much longer path difference.
However, there is a limit for thermal sources that I have seen in a physics books, which is connected to the maximum coherence time not exceeding 10-8s or 2..3m of path difference.
That is spatial coherence or the transverse coherence length. It tells you how point-like the light source is or what the maximal separation of slits may be to observe interference in a double slit experiment.
For interference filters, the longitudinal coherence length (coherence time times the speed of light) is the relevant quantity. The coherence time is essentially given by the Fourier transform of the power spectral density of your light field. Simply speaking: a broad spectrum results in a short coherence time. Therefore, one may improve coherence time by spectral filtering. Depending on what is going on in the atmosphere, sunlight filtered by the atmosphere is usually considered to have a coherence time on the order of one to few femtoseconds:
https://www.nature.com/articles/s41598-022-08693-0
A coherence time of 1 femtosecond corresponds to a longitudinal coherence length of about 300 nm.
interesting article in Nature, but it doesn't give the answer to the topic starter question, asking why a thick multilayer coating is working while sunlight has a very short coherence length.
The Fabry-Perot effect (present in interference filters) is often taught as multiple reflections that occur that then might need fairly long coherence lengths to be completely effective. You might find this Insights article that I authored a few years ago of interest, where the interference effects can occur at a single dielectric interface, and where multiple reflections are not the fundamental reason why the interference occurs. The multiple layers with the multiple interfaces do play a role, but as this article explains, interference occurs from two mutually coherent sinusoidal sources incident onto a single dielectric interface from opposite directions.
See https://www.physicsforums.com/insights/fabry-perot-michelson-interferometry-fundamental-approach/
I need to add one more item to the above=at each dielectric interface in the multi-layer system there is a right-going wave and also a left-going wave (amplitude) on the left side of the interface, and also a left-going wave and a right-going wave on the right side of the interface. There is a phase relation depending on the path distance of each layer that also comes into play, (between the right-going waves at adjacent interfaces, etc. and between the left-going waves at adjacent interfaces). This is how the multi-layer problem is solved rather than trying to compute all possible multiple reflections.
Edit: For the coherence length calculation, it would appear that all you would need to get interference with such a multi-layer system is a coherence length that is perhaps 2 or 3 times the optical thickness of each layer.
Multilayer dielectric coatings can be designed to have a (nearly) arbitrary spectral reflectivity- ultrabroadband is a simple example:
https://www.laser2000.com/en/mirrors/82436-ultra-broadband-dielectric-mirror.html
How do multilayer dielectric coatings work? Any decent optics book will have a thorough discussion. Apps can design the specifics based on your desired reflectivity profile, and companies can fabricate your designs
https://www.rp-photonics.com/rp_coating.html
https://www.chroma.com/capabilities/manufacturing
Note- the thickness of each individual layer of a multilayer coating is indeed less than the coherence length of the light source.
This is the key! In my previous post above I incorrectly cited the spatial/transverse coherence length of sunlight, but the crucial parameter for multilayer interference-filters is the temporal/longitudinal coherence length, which is indeed ##\sim 1\mu m## as stated by the OP. As long as each individual layer thickness is less than this value, a multilayer filter will work for any overall stack height. Here's a reference that discusses designing filters by this criterion: Optical model for multilayer structures....
From the introduction:
"Optical models for thin-film multilayer structures are used in several important applications such as design and analysis of optical coatings and thin-film solar cells. The objective of these optical models is to predict reflectance, transmittance or absorption depth profile as a function of wavelength. For accurate calculation of these parameters it is crucial that the interference between multiple internal reflections is taken into account correctly. Thus far this has been especially challenging for thin-film solar cells which typically have an absorber layer thickness on the order of the coherence length of the incident sunlight. Layers with an optical thickness less than the coherence length of the incident light cause observable interference fringes and are commonly referred to as coherent layers. Much thicker layers, that do not give rise to observable fringes, are referred to as incoherent layers. Partly coherent layers represent the intermediate case."
Very good, and I pretty much agree with the previous two posts, but there IMO is something missing from the standard explanations of multiple reflections and/or the case of multiple layers with a left-going and right going wave amplitude on each side of the interfaces. It took a number of years for me to see the part that I originally couldn't put my finger on, and that is mentioned in post 7: The second interface for the Fabry-Perot effect is needed to make multiple reflections, but its real purpose is to provide for the left-going wave incident on the first interface=that way you have two waves from opposite directions incident on the first interface and interference results from this simplest of systems. ( I was surprised myself when I discovered that interference results from the emerging waves from two sinusoidal sources incident onto a single interface from opposite directions that completely conserves energy). Edit: Note that the resulting energy redistribution from these two sources will change as the phase of the left-going wave is changed=the distance to the second interface is indeed important.
Otherwise, yes, the standard explanations written up in the literature will get you the results that you need, but this fundamental process is often ignored. With it, both the Fabry-Perot and Michelson interferometers function from the same fundamental concepts, and the two aren't as different as the standard explanations could lead one to believe=in both of them there are two waves incident from different directions onto a dielectric interface, and the emerging wave amplitudes interfere, with the result that the energy redistribution depends on the relative phases of the two incident waves. (Note that the dielectric interface splits each wave into two components=a reflected and a transmitted).
The sunlight comprise emission events from many atoms with a temporal coherence on a level at least 10-11s or longer. That mean the filtered sunlight coherence length may exceed > 1cm or more. The fact that the thick multilayer interference coating if working evident the the light coherence of elementary atoms bursts are much longer then the thickness of the coating.
Another example I can take is the Lunt Fabry–Pérot interferometer used for the observation of the Sun in H-alfa.
From the picture above it is easy to calculate that the path length between two parallel mirrors is 525 waves or 344µm. The width of the narrow peaks suggest that reflective coefficient is about 0.9 or so. Taking into account that the light is traveling the gap multiple times, > 20..30 times to decay, that gives the coherence length well above 2..3 cm to make it works.
Taken from Britannica Propagation and coherence
Light from the Sun or from a lightbulb comes in many tiny bursts lasting about a millionth of a millionth of a second and having a coherence length of about one centimetre. The discrete radiant energy emitted by an atom as it changes its internal energy can have a coherence length several hundred times longer (one to 10 metres) unless the radiating atom is disturbed by a collision.
Would be the "intrinsic" coherence length just above a single layer thickness the entire multilayer coating would not work! The fact the the multilayer coating is working with high efficiency evident that the "intrinsic" coherence is much-much longer than the entire coating thickness.
renormalize said:
.. the crucial parameter for multilayer interference-filters is the temporal/longitudinal coherence length, which is indeed ##\sim 1\mu m## as stated by the OP. As long as each individual layer thickness is less than this value, a multilayer filter will work for any overall stack height.
Misleading sentence.
I want to emphasise once more that the coherence length of broadband white light has nothing with the ability of the thick multilayer coating to work.
The fact that multilayer coating does work declare that the intrinsic coherence length of the elementary emission events combining the white light is indeed many times longer than the thickness of the coating otherwise it would not work.
The calculation for the distance between mirrors in a Fabry-Perot cavity is ## d=\frac{\lambda^2}{2 \, \Delta \lambda} ## (where ## \Delta \lambda ## is the spacing between peaks in the spectral transmission curve) which is one half of what you computed. (Comes from ## m \lambda_1=2nd ##, and ## (m-1)\lambda_2=2nd ##).
Meanwhile a google seems to suggest that the coherence length of the H alpha line is a few millimeters, and I think it is likely that it has a longer coherence length than the blackbody type portion of the solar spectrum.
I'm inclined to believe that the coherence length necessary for the layered interference filter to work will be about 3 or 4 times the width of each layer (rather than depending upon the width of the entire stack), but we don't have an authoritative source on that yet that anyone has referenced.
Can you provide a reference which quantifies this claim involving total coating-thickness instead of individual layer thicknesses? Like, e.g.:
"A multilayer interference filter of total thickness ##T## will function with ##X##% efficiency under light with coherence-length ##L## provided that ##T## satisfies ##T\leq\Lambda L##, where ##\Lambda=(\text{specified})##."
One or two additional comments on post 12: I'm assuming this is the experimental result of the transmission spectrum run with a diffraction grating type spectrometer, where most likely an incadescent source (typically about a 2500 K blackbody) was used, with one run with the Fabry-Perot etalon, and the other without it. The optical path length 2d=344 microns was computed, and that would indicate the 2500 K blackbody source must have a coherence length a good deal greater than that.
I don't know that we are getting good numbers for the coherence length of solar light. In an early post it was stated to be around one micron in length, but a google indicates it to be in the 50 micron range. The fact that the OP's filter works leaves this as an open item, but it would be nice if we could determine if the coherence length needs to be of the order of a couple of layers of the interference filter or the width of the entire stack. I am going with the former.
As I mentioned in post #10, there are two coherence-lengths for sunshine: spatial/transverse (##\sim 50\mu\text{m}##) and temporal/longitudinal. It is this second quantity that is relevant for multilayer interference filters. From the discussion on pg. 2 of The coherence time of sunlight..., depending upon its definition, the temporal coherence time of sunlight is quoted in the range ##0.58-3\text{fs}##. Using the vacuum speed-of-light ##0.3\mu\text{m}/\text{fs}##, this corresponds to a longitudinal coherence length of ##0.17-0.9\mu\text{m}##.
I doubt that the number is less than one micron. If that were the case, even the single layer of a stack of thin film layers would fail to operate.
I must admit, I lack expertise in this area in regards to the individual photons or groups of them in the same boson mode, and what they are defining as a coherence length. Meanwhile though, I did spend a lot of time working the interferometer concepts, (Fabry-Perot and Michelson), and that's something that I think others might find useful. See e.g. posts 7, 8, and 11.
That's not true.
A layer that's thicker than the light coherence-length still functions optically to a calculable degree; i.e., it is partially coherent. Have you read the reference I gave in post #10? From its conclusion:
"In summary, we showed that the net-radiation method can be used for coherent calculations of multilayer structures. We demonstrated that by averaging only a few calculations with equidistant values of ϕ, the coherence of any layer can be removed partly or completely. This makes this relatively simple method a powerful optical design tool for multilayer structures consisting of coherent, partly coherent and incoherent layers, such as thin-film solar cells. We illustrated this method by optical simulation of an a-Si-H solar cell with various degrees of absorber layer coherence."
renormalize said:
That's not true.
I just read through it=thank you. E. Hecht is listed in the article near equation (10) as saying the coherence length for sunlight is about one micron. His Optics book (Hecht and Zajac) is a good one and we'll have to go with that. From what I could get from the article, it seems they are saying the distance of interest is the thickness of the individual layers. I don't know that they came out and stated it explicitly, but it seems that is what they are calculating.
Meanwhile though, I do think the coherence length does need to be nearly one micron for these filters to work=otherwise you start getting in a region where the coherence length is shorter than the wavelength where you are trying to generate interference. e.g. a coherence length of 0.2 microns would not work. (Note the visible light at wavelength of 600 nm is 0.6 microns)
While the coherence length of unfiltered sunlight is less than one micron, it is possible to enhance the coherence by using a bandpass filter. However, the coherence length can only be improved up to a certain limit, which is determined by the lifetime of the emitters.
You seem to be changing your opinion from that of post 13, but that is ok. One of the purposes of the discussion is to try to learn something. :)
May I refer to the echelle spectrometers used for star and Sun observation?
In multilayer coating interference is occurred between reflections from multiple layers, in diffraction gratings interference is occurred between light diffracted from different grooves across grating aperture. Echelle gratings are used with large angle of incidence that makes quite large path difference across the aperture.
How large the size of echelle gratings that used for stars/sun?
There are plenty references about 300..400 mm size.
The echelle spectrometer for Giant Magellan Telescope (GMT) is planning to us echelle with 0.3 x1.25 m size (here is the link The optical design of the G-CLEF Spectrograph ),:
That would be above 1m of the optical path different across the aperture. I understand that they assume that the light from stars would be coherent otherwise it would be not possible to realize the planned spectral resolution of the spectrometer.
Can you expand on this? In general terms, what type of bandpass filter design(s) would be suitable for producing filtered sunlight with a longitudinal coherence-length greater than ##1\mu\text{m}##?
I am simply repeating what I have read in physics textbooks (which I revisit from time to time to refresh my memory).
White light consists of numerous acts of elementary emission. Undisturbed atoms can emit light for durations of about 10−6..10-8 seconds, producing electromagnetic waves that consist of up to 106..108 cycles before the phase changes randomly. Collisions between atoms can shorten both the time and length of these undisturbed emissions. Interference can occur only if the path difference does not exceed the length of an individual elementary emission act.
Thus, the ability to produce interference is not inherently limited to 1 µm for white light; its intrinsic coherence length is much longer. However, without filtering, the interference cannot be revealed. For example the human eye can distinguish colors and observe tens of Newton fringes even in daylight, much more than suggest 1um coherence length. Before I have used other examples to explain this subject.
I've listed my references that state ambient sunlight has a longitudinal coherence-length of ##\sim 1\mu\text{m}## or less. Yet you claim "its intrinsic coherence length is much longer". Can you please cite scholarly references that explicitly support this specific claim and quantify "much longer" with actual numbers? If you can't, this seems like a personal theory.
I found one "link" on the subject that may be of interest. Perhaps I can help @Gleb1964 on this item.
See https://mpl.mpg.de/fileadmin/user_upload/Chekhova_Research_Group/Lecture_5_2.pdf
They have the formula ## l_{coh} \approx \frac{\lambda^2}{2 \, \Delta \lambda} ##.
This would suggest that if we run the sunlight through a diffraction grating spectrometer, and sample a very small ## \Delta \lambda ## using narrow slits that this light would then have a very long coherence length=far beyond one micron (by a factor of 1000 or more).
I think @Gleb1964 may have it correct, while for a broad solar spectrum, the ## \Delta \lambda ## is approximately ## \lambda ##, which is consistent with the one micron number for the coherence length. Hopefully this helps.
renormalize said:
Can you please cite scholarly references that explicitly support this specific claim and quantify "much longer" with specific numbers? If you can't, this seems like a personal theory.
As you wish, here is fragment from Sivuhin Optics T.5
..removed...
Translation of essential part:
An example of this is the radiation from an isolated atom. An excited atom emits a series or, as it is commonly called, a wave packet during the emission time Temission, which typically lasts around 10^{-8} seconds. Such a wave packet (or can be translated as a wave train) contains 10^6..10^8 waves. During this time, the atom "de-excites" and transiting to an unexcited state. Due to various processes, such as collisions with other atoms or impacts from electrons, the atom can return to an excited state and then begin emitting a new wave packet. As a result, a sequence of wave packets is emitted by the atom at short and irregularly changing intervals.
I have to struggle to find a similar explanations, may be here is saying something similar 5.3.1 Coherence of Light Sources. Unfortunately not about thermal light sources.
But I have translated the essential part of text above. I hope it helps.
