Effects of gravity on different elements
A 100lb lead ball and a 100lb copper ball would roll down a 35-degree ramp at the same speed under ideal conditions, as gravity affects all objects equally regardless of material. However, differences in size due to varying densities could influence rolling resistance and air drag, potentially affecting the results. The larger contact area of the copper ball might have a minimal impact, but it is unlikely to be significant. Additionally, both materials being conductors could introduce minor effects when moving through Earth's magnetic field, though these would be difficult to detect. Overall, eliminating all variables would result in both balls rolling down the ramp at the same speed.
JesseTH
Hi,
Hopefully this is the right place for this question.
I'm wondering whether a 100lb ball of lead would roll down a ramp (assuming a 35 degree slope) at the same speed as 100lb ball of copper.
Would there be a difference in force while they are rolling down?
Thanks,
Might be interesting to watch...
Thanks CWatters..
I do understand that with no 'interference' the two would fall at the same speed.
But would the larger contact area of the copper ball on the ramp surface be enough to affect results (here on earth)?
This kind of experiment has been done many times in many different ways, going back to Galileo. The "effect of gravity" (acceleration due to gravity) depends only on the mass of the object, not the material it is made of.
JesseTH said:
Thanks CWatters..
Any difference could potentially change the results but it might be a small. If the balls are different sizes (which they would be as they have different densities) then rolling resistance or air drag might be different and that would change the results.
If you eliminate every possible difference (same mass, size and rolling resistance and EDIT: Moment of inertia) so that they are the same except for the element that are made from then no, they would both roll down at the same speed.
How small a difference counts as different? Both lead and copper are electrical conductors and they have different conductivities. On Earth they would be moving through the Earth's magnetic field and that might affect the results - but it would be an exceptionally small effect that is hard to detect.
I'm not a student or graduate in Astrophysics.. Wish i were though... I was playing with distances between planets... I found that Mars, Ceres, Jupiter and Saturn have somthing in common... They are in a kind of ratio with another.. They all got a difference about 1,84 to 1,88x the distance from the previous planet, sub-planet. On average 1,845x. I thought this can be coincidential. So i took the big moons of Jupiter and Saturn to do the same thing jupiter; Io, Europa and Ganymede have a...
  • · Replies 32 ·
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 20 ·
