Effects of KE & PE of a Harmonic Oscillator under Re-scaling of coordinates
The discussion revolves around the effects of rescaling coordinates on the kinetic and potential energies of a harmonic oscillator, specifically examining the implications of substituting the wavefunction with a scaled variable. Participants explore how these changes affect the average kinetic energy and potential energy in terms of the scaling factor, λ.
  • Participants discuss the substitution of variables in the Schrödinger equation and how this impacts the kinetic and potential energy terms. Questions arise about the validity of assumptions regarding energy conservation and normalization of the wavefunction after transformation.
The conversation is ongoing, with participants providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the proper form of the Schrödinger equation and the implications of variable substitution, but no consensus has been reached on the final interpretation of the results.
There are indications that the original problem statement may not have been fully conveyed, leading to potential misunderstandings about the nature of the transformation being discussed. Participants are also grappling with the normalization of the wavefunction after rescaling.
Baibhab Bose
A particle in a one-dimensional harmonic oscillator potential is described by a wave-function Psi(x,t)
߰ If the wavefunction changes to ߰Psi(Lambda*x ,t) the expectation value of kinetic energy ܶ
and the potential energy ܸ will change, respectively, to
The Schrodinger equation
The wavefunction is Ψ(x,t) ----> Ψ(λx,t)
What are the effects on <T> (av Kinetic energy) and V (potential energy) in terms of λ?
From ## \frac {h^2}{2m} \frac {\partial^2\psi(x,t)}{\partial x^2} + V(x,t)\psi(x,t)=E\psi(x,t) ##
if we replace x by ## \lambda x ## then it becomes ## \frac {h^2}{2m} \frac {\partial^2\psi(\lambda x,t)}{\partial x^2}\frac {1}{\lambda^2} + \lambda^2 V(\lambda x,t)\psi(\lambda x,t)=E\psi(\lambda x,t) ##
so would the argument be like, to keep the energy as it is the first term should be neutralized by and extra ##\lambda^2## term in the average KE (interpretation of the first term). and similarly V(##\lambda x ,t)## should be divided by ##\lambda^2## ?
and again, why should I assume that the total energy remains same?
The above is not a correct form for the Schrödinger equation either time-dependent or time-independent. I suggest that you stick with the time-independent form.
Avoid guessing. What if you made the substitution ##u = \lambda x##? Then you should be able to cast the TISE in terms of ##u## and deduce the energy by comparison with the usual form when ##\lambda =1##.
Yes, so then if I write KE in terms of u, i.e. ## \frac{ħ^2}{2m}\frac {\partial^2 \psi (u)}{\partial u^2}=<T>##
and multiplying by ##\lambda^2## both sides ##\lambda^2\frac{ħ^2}{2m}\frac{1}{\lambda^2}\frac {\partial^2 \psi (\lambda x)}{\partial x^2}=\lambda^2<T>##
=>##\frac{ħ^2}{2m}\frac {\partial^2 \psi (\lambda x)}{\partial x^2}=\lambda^2<T>##
this is how we arrive at the conclusion right?
¥ou did not write the time-indepemdemt Schrödinger equation in terms of ##u##, you wrote what you think is the expectation value for the kinetic energy, which it isn't. On the left side you have a function and on the right side you have a constant. It looks like you are confused about quantum mechanical operators and expectation values.
Oh, that's a bad mistake!
So ##\frac{ħ^2}{2m}\frac{\partial^2\psi(u)}{\partial u^2}+V(u)\psi(u)=E\psi(u)## is the time independent Schrödinger equation in terms of ## u=\lambda x##... (1)
so this E is equivalent to the case when ##\frac{ħ^2}{2m}\frac{\partial^2\psi(x)}{\partial x^2}+V(x)\psi(x)=E\psi(x)##...(2)
the same energy eigenvalue.
Now when we express the (1) expanding u as ##\lambda x## then it becomes
##\frac{ħ^2}{2m}\frac{\partial^2\psi(\lambda x)}{\partial x^2}\frac{1}{\lambda^2}+\lambda^2V(x)\psi(\lambda x)=E\psi(\lambda x)## since Harmonic oscillator potential is ##1/2mω^2 x^2##.
Now how can I draw conclusions about Kinetic and Potential energies? How they have changed due to this scale shift..?
First off there is a negative sign in front of the ##\frac{\hbar^2}{2m}## term on the Schrödinger equation. Secondly, you still don't get it. Start with$$-\frac{\hbar^2}{2m}\frac{\partial^2 \psi(x)}{\partial x^2}+\frac{1}{2}m\omega^2 x^2\psi(x)=E\psi(x)$$ and then let ##u=\lambda~x##. Write the equation above in terms of ##u## and then bring it to a form so that the kinetic energy term is ##-\dfrac{\hbar^2}{2m}\dfrac{\partial^2 \psi(u)}{\partial u^2}.## Compare what you get with the equation above.
Okay, if I substitute ##u=\lambda x## to the ## -\frac{ħ^2}{2m} \frac{\partial^2\psi(x)}{\partial x^2}+V(x)\psi(x)=E\psi(x)## , then it becomes something like
## -\frac{ħ^2}{2m} \frac{\partial^2\psi(\frac{u}{\lambda})}{\partial u^2}\lambda^2+V(u)\psi(\frac{u}{\lambda})\frac{1}{\lambda^2}=E\psi(\frac{u}{\lambda})##
now what can I do to make this ##\psi(\frac{u}{\lambda}) ## to
##\psi(u)## ?
OK, let's do this a bit differently. In post #1you had the right idea. If the wavefunction changes from ##\psi(x)## to ##\psi(\lambda x)## as the problem suggests, the correct time-independent equation is
$$-\frac {h^2}{2m} \frac {d^2\psi(\lambda x)}{d x^2} + \frac{1}{2} m\omega^2x^2\psi(\lambda x)=E\psi(\lambda x)$$which is not what you have. As I already suggested in post #6, write the equation above in terms of ##u## and then bring it to a form so that the kinetic energy term is ##-\dfrac{\hbar^2}{2m}\dfrac{d^2 \psi(u)}{d u^2}## and there are no ##x## terms in the equation but only ##u## terms.
Yes. this is clear now. I am getting the right answer.
By I want to discuss and alternate with you.
Syntactically ##<T>=\frac{h^2}{2m}\int \psi(x)* \frac{\partial^2}{\partial x^2} \psi(x)\, dx##
So, here if we change ##\psi(x)--> \psi(\lambda x)## then to scale we need to shoot two lambdas down the partial term and one for the dx term to make it fully in terms of##u=\lambda x## but, consequently there will be two lambdas in the numerator and one in denominator; effectively one lambda term for this whole kinetic energy.
So, the KE re-scale amounts to ##\lambda <T>##
If this is true, it'd be weird because none of the options in my question mentions this kind of answer.
but the logic is air, don't you think?
When I wrote
I meant write the entire Schrödinger equation, not what you think is the expectation value of the kinetic energy. Do that and the logic will not appear to be air. Also, if you have to "shoot lambdas", do not describe it with words, but show it algebraically with equations. It helps spotting possible mistakes.
Syntactically ##<T>=-\frac{h^2}{2m}\int \psi(x)* \frac{\partial^2}{\partial x^2} \psi(x)\, dx##
So, here if we change ##\psi(x) \to \psi(\lambda x)## then to scale we need to shoot two lambdas down the partial term and one for the dx term to make it fully in terms of##u=\lambda x## but, consequently there will be two lambdas in the numerator and one in denominator; effectively one lambda term for this whole kinetic energy, so the KE re-scale amounts to ##\lambda <T>##.
Your reasoning is right here, but you still need to account for the fact that ##\psi(\lambda x)## is not normalized.
I'm wondering if you provided the problem statement exactly as it was given to you. @kuruman's discussing what happens when you transform the coordinate ##x \to \lambda x## whereas the problem statement seems to asking a different question where you replace ##\psi(x)## by a new state ##\psi(\lambda x)##. In the latter case, if ##\psi(x)## is a solution to the TISE, ##\psi(\lambda x)## won't be one, but you can still calculate expectation values.
Thank you. This point of Normalization seems so critical here. so I normalized ## \psi(\lambda x) ## and ## \sqrt {\lambda} ## was the Normalization constant and then I did the averaging again which yielded the correct answer which is ## \lambda^2<T> ##
