Efficiency of an elastic band. Hooke's Law
The discussion focuses on calculating the efficiency of an elastic band using Hooke's Law and the work-energy theorem. The participant outlines their experimental setup, including parameters such as mass (1.85g), force (2.6N), and extension (6.4cm). They derive the efficiency formula as 100[1 - (energy lost/initial energy)], ultimately calculating an efficiency of 66.18%. The conversation emphasizes the importance of measuring the height attained during the experiment and suggests varying the extension to observe efficiency trends.
  • Understanding of Hooke's Law (F = -kx)
  • Basic principles of potential energy (PE = mgh)
  • Familiarity with the work-energy theorem
  • Ability to perform calculations involving energy loss and efficiency
  • Learn how to derive the spring constant (k) through static experiments with various masses
  • Explore the concept of energy loss in non-ideal elastic materials
  • Investigate methods for measuring amplitude and its impact on efficiency
  • Research the effects of varying extensions on the performance of elastic bands
Students conducting physics experiments, educators teaching mechanics, and anyone interested in the practical applications of Hooke's Law and energy efficiency in elastic materials.
Atomicbomb22
I am doing a lab experiment and the objective is to find the efficiency of an elastic band.
Distance to ceiling=2.9m
Mass of elastic band= 1.85g
Force 2.6N (found using Newton meter)
Extension: 6.4cm
Well I am not looking for a solution, I just need the way to setup the formulas in order to find efficiency.
F1=-kx (Hooke's Law)
F2=ma
I think that I should compare the force stored in the elastic band as mechanical energy to the force required to make the rubber band hit the ceiling.
so I'd do this:
-kx=ma
Problem is that I don't know if acceleration should be taken to be gravity. Once I find acceleration, I should be able to find the initial velocity. Then, couldn't I use the work-energy theorem to compare the theoretical initial velocity to the actual velocity? Meaning, I compare the initial velocity I get when I use mgh=1/2mv^2 to the velocity I get when using acceleration.
Sorry maybe what I said above is completely wrong. Please help, I was missing from class when the teacher went over it.
Actually I think I figured it out. Should I do the following?
Potential Energy of Spring=1/2kx^2
Potential Energy at cieling= mgh
so I just compare the P.E of the spring and the PE of the elastic band at the cieling. The PE of the Spring> than PE at cieling because some energy is lost, and 1-%age loss is efficiency.
Does that seem right? This lab is very important so your help is appreciated.
efficienciency seems like a strange word to use, normally we talk about non-ideal behavior or non-Hookean behavior in situations like this. Both eqns are valid F=ma=-kx as well as mgh=1/2kx^2 but not sure exactly what's being described with your setup.
Well my teacher said "efficiency" is:
Energy in/Energy out
Basically, I need to find out how much (as a %) the elastic band deviates from the ideal elastic band due to energy loss.
My experiment is basically like this:
m=0.00185kg
g= -10ms^-2
h=2.93m
k= -40.0
x= 0.064
Now if this was an ideal band then the following would be true:
mgh=0.5kx^2
mgh=(0.00185)(-10)(2.93)=-0.0542
0.5kx^2=(0.5*-40.0)(0.064)^2=0.0819
So, 0.0819-0.0542=0.0277J has been removed from the system
So, 100[1-(0.0277/0.0819)]= 66.18% efficient
Does that seem correct?
Here's where I get confused, the k should be derived from static experiment with various masses. Then I believe what you descibe makes very good sense, since that would more accurately reflect energy lost vs purely non-linear elongation of band.
Yea i derived k from experiment, I just used 40 as an example. But the problem is that I only have the height attained (h) for one experiment. You think I need to redo the experiment or can I somehow derive height (h) with the the variables I know?
Thanks for all your help so far.
hey if h of 2.93 is what you measured, that's the number to use. For completeness since you gave the mass of the band itself, that should be included if possible. and your calcs for effieciency show 40, so use whatever you determined. One other way to have done this is to watch over several cycles how the amplitude dimished. If you were to redo, I'd think about trying that.
Well, I varied the extension of the rubber band for each time I repeated the experiment. So it obviously won't go as high (if with 200J it goes 2.93m, with 150J it won't go 2.93m), and I didn't measure the new height. I think that's what you mean by amplitude. Guess I made a stupid mistake, I'll do like you said, luckily I still have the rubber band.
Its difficult to explain, but after the first experiment, instead of measuring the height, I simply measured the force and the extension (using a Newton meter and ruler). Seems like I really did do a silly mistakeThanks a lot
Right, amplitude is height in this case. Your approach ov varying the extension is a good idea. then you get efficiency measurements which vary over a range, and may show some interesting trends.
  • · Replies 35 ·
  • · Replies 17 ·
