Efficient Differentiation of Hyperbolic Integrals
12 replies · 3K views
nayfie
Hello again :)
I get the feeling I'm missing some kind of 'trick', as this is proving a very difficult question :(
I'll write out my frustration below;
Find f'(x) if f(x) = [itex]\int^{cosh(x^{2})}_{0} tanh(t^2)dt[/itex]
My idea was to find the value of the integral (using integration by parts), simplify it and then differentiate it.
However, this method seems rather time consuming (and difficult).
Am I missing something?
Fundamental Theorem of Calculus. What does it say? I am not talking about evaluating a definite integral
You mean that [itex]\frac{d}{dx} \int^{x}_{a} f(t)dt = f(x)[/itex]?
Does this imply that [itex]\frac{d}{dx} \int^{cosh(x^{2})}_{0} tanh(t^2)dt = tanh(cosh^2(x^2))[/itex]?
Not quite. The statement of the fundamental theorem has an x as the upper limit. You have a function of x as the upper limit. That makes a difference.
Yes, that's what flyingpig is talking about.
No - you're neglecting to use the chain rule.
[tex]\frac{d}{dx} \int^{u(x)}_{a} f(t)dt = \frac{d}{du}\int^{u(x)}_{a} f(t)dt * \frac{du}{dx} = f(u) * \frac{du}{dx}[/tex]
nayfie said:
Find f '(x) if f(x) = [itex]\int^{cosh(x^{2})}_{0} tanh(t^2)dt[/itex]
This is how I like to thing about this:
Suppose the anti-derivative of tanh(t2) is G(t), i.e. G'(t) = tanh(t2).
For you problem this means that f(x) = G(cosh(x2)) - G(0).
What does that give you for f '(x) ? (Don;t forget to use the chain rule.)
First of all, thank you all for the contributions :)
I think I have arrived at an answer! Let me know if I've made a mistake.
[itex]f(x) = \int^{cosh(x^{2})}_{0} tanh(t^{2})dt[/itex], let [itex]tanh(t^2) = g(t)[/itex]
[itex]f(x) = G(cosh(x^{2})) - G(0)[/itex]
[itex]f(x) = G(cosh(x^{2}))[/itex]
[itex]f'(x) = G'(cosh(x^{2})) = g(cosh(x^{2}))[/itex]
[itex]f'(x) = tanh(cosh^{2}(x^{2})).sinh(x^{2})[/itex]
You're on the right path! :smile:
But I'm afraid you haven't applied the chain rule properly yet.
This means that f'(x) = G'(t(x)) t'(x).
So you 4th line doesn't follow from the 3rd.
Actually now that I look at it again I think the chain rule needs to be applied twice?
[itex]f'(x) = G'(cosh(x^{2})) = g(cosh(x^{2})).sinh(x^2).2x[/itex]
[itex]f'(x) = tanh(cosh^{2}(x^{2})).sinh(x^{2}).2x[/itex]
It's been a long day :(
Well, your day just came into fruition!
That's it! :smile:
You shouldn't assume G(0) = 0. It turns out when you differentiate, it goes away, so it doesn't matter in the end. But you shouldn't simply erase it.
