Effortlessly Create a Matrix in Latex: Step-by-Step Guide
  • Context: LaTeX
  • Thread starter Thread starter ryan88
    Latex Matrix
7 replies · 15K views
ryan88
Hi,
I am trying to produce a matrix in Latex with the following code:
Code:
\begin{bmatrix}
1 & 0 & 0 & 0 & 0 & 0 & 0 & -4 & 1 & 0 & 0 & 0 & 0 & 0 \\
0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 & 0 & 0 \\
0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 & 0 \\
0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 \\
0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 \\
0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 \\
0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4
\end{bmatrix}
But I keep on getting the following error:
Extra alignment tab has been changed to \cr.<recently read> \endtemplate
This error occurs for each row in that matrix.
I would appreciate any help anyone can give,
Thanks,
Ryan
I create matrices like this
Code:
\begin{equation}
\left[
 \begin{array}{ccc}
   1 & 0 & 0\\
   0 & 1 & 0\\
   0 & 0 & 1
 \end{array}
\right]
\end{equation}
I just copied your code into tex and it gives
[tex]\begin{bmatrix}<br /> 1 & 0 & 0 & 0 & 0 & 0 & 0 & -4 & 1 & 0 & 0 & 0 & 0 & 0 \\<br /> 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 & 0 & 0 \\<br /> 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 & 0 \\<br /> 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 \\<br /> 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 \\<br /> 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 \\<br /> 0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4<br /> \end{bmatrix}[/tex]
Is there a maximum of 10 columns in a matrix?
If we try to do it "by hand" (using \begin{array})
[tex]\left[\begin{array}{cccccccccccccc}<br /> 1 & 0 & 0 & 0 & 0 & 0 & 0 & -4 & 1 & 0 & 0 & 0 & 0 & 0 \\<br /> 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 & 0 & 0 \\<br /> 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 & 0 \\<br /> 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 & 0 \\<br /> 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 & 0 \\<br /> 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4 & 1 \\<br /> 0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 1 & -4<br /> \end{array}\right][/tex]
The code for that is
\end{array}\right]
Notice that, using \begin{array}, you need to put in the braces (\left[ and \right]) yourself (so you could use ( ), { }, etc.). The {cccccccccccccc} (14 c's) tells LaTex there are 14 columns.
Thanks, that worked great.
Ryan
(I believe) There is a default for the maximum number of columns in the matrix environments, and that it is possible to change it in your document.
I don't have the pertinent information at my fingertips now; perhaps a search of tug.org
or some other site would be fruitful.
Edit: spoke too soon: from AMS math documentation, footnote on page 10.
More precisely: The maximum number of columns in a matrix is determined by the
counter MaxMatrixCols (normal value = 10), which you can change if necessary using LATEX’s
\setcounter or \addtocounter commands.
Thanks statdad.
Is there any advantage of using \begin{bmatrix} over \left[\begin{array}?
Ryan
ryan88 said:
Thanks statdad.
Ryan
That I can't say, as I use the "bmatrix" environment exclusively. As some other posters have shown, it is possible to control column alignment in arrays; I don't know of a similar feature with the matrix environments.
