How Long Does It Take for Pressure to Increase in a Punctured Container?
  • Thread starter Thread starter Physgeek64
    Effusion Pressure
The discussion focuses on calculating the time required for the pressure inside a thin-walled container to rise from 10-7 mbar to 10-6 mbar after a small hole of area 10-17 m2 is made. The relevant equations include the effusion rate, represented as dN/dt = A(n/4), where n is the number of particles per unit volume of outside air and is the average speed of air molecules. The average speed is derived from the Maxwell-Boltzmann distribution, with an approximation for the molecular weight of air at 30. The solution confirms that the relationship between time and the number of particles is linear under the given conditions.
  • Understanding of gas laws and effusion principles
  • Familiarity with the Maxwell-Boltzmann distribution
  • Basic knowledge of differential equations
  • Concept of molecular weight and its significance in gas calculations
  • Study the derivation of the Maxwell-Boltzmann distribution and its applications
  • Learn about the principles of effusion and diffusion in gases
  • Explore the impact of initial conditions on differential equations
  • Investigate the relationship between pressure, volume, and temperature in gas dynamics
Students in physics or engineering, particularly those studying thermodynamics and fluid dynamics, as well as professionals involved in gas behavior analysis and container design.
Physgeek64
A thin-walled container of volume 10−3 m3 is evacuated to a pressure of 10−7 mbar. The vessel is surrounded by air at 1 bar and 290 K. If a small hole of area 10−17 m2 is made in the wall of the container, how long does it take the pressure inside to rise to 10−6 mbar?
##\frac{dN}{dt}=A\phi = \frac{A<v> N}{4V}##
## \frac{dN}{N}=\frac{A<v>}{4V} t ##
##t=\frac{4V}{A<v>}\ln{\frac{P_2}{P_1}}##
However this requires us to know m and i can't see how to figure this out. Therefore i am assuming my solution is wrong...
Many thanks in advance
Your original differential equation is incorrect. You are assuming the effusion only goes in one direction is this problem (that is ok), but the equation should read ## \frac{dN}{dt}=\frac{A n \bar{v}}{4 } ## where ## n ## is the number of particles per unit volume of the outside air. (## N ## is the number of particles of air inside the container). This ## n ## is constant and does change. One number you will need is ## \bar{v} ##. Average speed ## \bar{v} ## in a Maxwell-Boltzmann distribution is given by ## \bar{v}= (\frac{8}{\pi}) (\frac{kT}{M})^{1/2} ## , editing: ## \bar{v}=(\frac{8 kT}{\pi M})^{1/2} ##, where ## M ## is the (approximate) mass of a molecule of air. Since ## N_2 ## has M.W.=28, and ## O_2 ## has M.W.=32 , using an average M.W.=30 is an ok approximation, even though the air is 78% ##N_2 ## and 21% ##O_2 ##.
Charles Link said:
Your original differential equation is incorrect. You are assuming the effusion only goes in one direction is this problem (that is ok), but ## dN/dt=A n \bar{v}/4 ## where ## n ## is the number of particles per unit volume of the outside air. (## N ## is the number of particles of air inside the container). This ## n ## is constant and does change. One number you will need is ## \bar{v} ##. Average speed ## \bar{v} ## in a Maxwell-Boltzmann distribution is given by ## (\frac{8}{\pi}) (\frac{kT}{M})^{1/2} ## where ## M ## is the (approximate) mass of a molecule of air. Since ## N_2 ## has M.W.=28, and ## O_2 ## has M.W.=32 ## \bar{M.W}=30 ## is an ok approximation, even though the air is 78% ##N_2 ## and 21% ##O_2 ##.
Oh okay, so will i end up with a simple linear relationship between t and N?
Yes. The pressure inside the container is small enough compared to the outside pressure that the rate of effusion into it is much higher than any effusion back out. And yes, the effusion rate into it will be constant. ## \\ ## And don't forget to include the initial condition of ## N_o ## that you start with already inside the container. ## \\ ## Just for an additional detail: In its entirety ## \frac{dN}{dt}=A (\frac{n \bar{v}}{4}-\frac{N \bar{v}}{4 V}) ##, and this second term on the right side can be considered small compared to the first term for this problem. (No need to solve the more detailed exact differential equation, because the second term is negligible here).
@Physgeek64 See also the additions to post 4 above. ## \\ ## Also one minor correction to the above: ## \bar{v}=( \frac{8 kT}{\pi M})^{1/2 } ##.
  • · Replies 23 ·
