Eigenvalue problem -- Elastic deformation of a membrane
9 replies · 5K views
shreddinglicks
An elastic membrane in the x1x2-plane with boundary circle x1^2 + x2^2 = 1 is stretched so that point P(x1,x2) goes over into point Q(y1,y2) such that y = Ax with A = 3/2* [2 1 ; 1 2] find the principal directions and the corresponding factors of extension or contraction of the elastic deformation. Sketch the shape of the deformed membrane.
det(A-lambda*I) = 0
(A-lambda*I)x = 0
Using det(A-lambda*I) = 0
I got
lambda = 4.5
lambda = 0
Using (A-lambda*I)x = 0
I got eigenvectors
x2*[1;1]
x2*[-.5;1]
What do I do next?
det(A-lambda*I) = 0
(A-lambda*I)x = 0
I got
lambda = 4.5
lambda = 0
Check your algebra. Both eigenvalues are incorrect.
I got eigenvectors
x2*[1;1]
x2*[-.5;1]
The first eigenvector is correct, although it appears that you got it by accident, not on purpose. The second one isn't correct.
What do I do next?
After you get the correct eigenvalues and eigenvectors, each eigenvalue will give the amount of stretch or compression in the direction of the associated eigenvector. That should give you some idea of how the circle will be deformed due to the transformation
Yes, it is incorrect. I recalculated.
lambda = 1.5 and 4.5
eigenvectors are:
x2*[-1 1]
x2*[1 1]
I'm confused about the next part. Am I plugging the eigenvalues into x2? Then Am I plugging the vectors into the circle equation x1^2 + x2^2 = 1?
Those still aren't right. The eigenvalues I get are both integer values. It would be helpful if you showed more of your work, such as the characteristic equation you're working with.
It's a good idea to check your work. If ##\lambda_1## is an eigenvalue with associated eigenvector ##\vec{x_1}##, then ##A\vec{x_1} = \lambda_1\vec{x_1}## should be a true statement. IOW, applying the matrix to an eigenvector should result in a scalar multiple of that eigenvector -- a vector that is longer or shorter or possibly pointing the opposite direction (if the eigenvalue is negative).
I have checked both of my eigenvalues and eigenvectors as described above.
eigenvectors are:
x2*[-1 1]
x2*[1 1]
These are the eigenvectors I get, but I have no idea how you're getting them, as your eigenvalues are both wrong.
The two directions of your eigenvectors define four points on the untransformed circle. Using the correct eigenvalues, the transformed points from the circle will be in the same direction as the eigenvectors, but pushed out or sucked in. The transformation should deform the circle into a rotated ellipse.
I checked my eigenvalues on MATLAB to be sure.
The hand calculation is also attached.
OK, my mistake. I wasn't using that factor of 3/2 in my calculations. Since both of your eigenvalues are positive, the points on the circle in the directions of your eigenvectors will be stretched out by factors of 1.5 and 4.5.
I want to understand this. So I have two answers.
One where
x2*[-1 1]' where x2 = 1.5
and the other answer is
x2*[1 1]' where x2 = 4.5
I plug each of these vectors into the circle equation and then plot?
The line in the direction of the vector <-1, 1> intersects the unit circle at ##(\frac{-\sqrt 2} 2, \frac{\sqrt 2} 2)## and at ##(\frac{\sqrt 2} 2, \frac{-\sqrt 2} 2)##. The transformation A will stretch these points out by a factor of 1.5 away from the origin. What are the coordinates of these two transformed points?
Do the same computations for the other eigenvector/eigenvalue pair.
Is that clear?
Makes perfect sense. I just didn't think of the vectors as having an infinitely long line traveling through its direction.
