Proving No Eigenvalues Exist for an Operator on a Continuous Function Space
The discussion revolves around proving that no eigenvalues exist for a specific operator on a continuous function space. The argument begins with the equation \(Af(x) = \lambda f(x)\), leading to \((\lambda - x)f(x) = 0\). Since \(x\) ranges over \([0,1]\) and cannot equal the constant eigenvalue \(\lambda\), the only solution is \(f(x) = 0\) for all \(x\), indicating no eigenvector exists. The discussion also touches on the case of \(\lambda = 0\), confirming that it leads to the same conclusion of \(f = 0\) everywhere. Ultimately, the necessity of separately proving that 0 is not an eigenvalue is questioned, as the logic applies universally to all \(\lambda\).
member 428835
Show no eigenvalues exist for the operator ##Af(x) = xf(x)## where ##A:C[0,1]\to C[0,1]##.
Nothing comes to mind.
Eigenvalues ##\lambda## for some operator ##A## satisfy ##A f(x) = \lambda f(x)##. Then
Af(x) = \lambda f(x) \implies\\
xf(x) = \lambda f(x)\implies\\
(\lambda-x)f(x) = 0.$$
How do I then show that no eigenvalues exist? Seems obvious one doesn't exists since ##\lambda-x \neq 0## for all ##x\in [0,1]##.
Well the argument is subtle.
Since ##x## ranges over every point in ##[0,1]## and the supposed eigenvalue is some constant you cannot have ##\lambda=x##, since the function ##x## is not constant.
And obviously ##f(x)\ne 0 ##, otherwise it wouldn't be an eigenvalues' problem.
You are in fact almost there. The condition
##(\lambda-x)f(x) =0## implies that we have ##f(x) = 0## for all ##x\neq \lambda##. By continuity however ##f=0##. Thus, no eigenvector exists, as any possible eigenvalue leads to the trivial solution.
Likes member 428835
This just seems so simple. See, the HW was assigned in three parts, where part b) asked to show 0 is not an eigenvalue and part c) asked to prove no eigenvalues exist. But if this is part c), then why bother doing b)? Have I missed anything about ##\lambda = 0##? It seems this logic holds for all ##\lambda##.
It also works for ##\lambda = 0##. Then your equation leads to ##xf(x) = 0 \forall x## and for ##x \neq 0## we then have ##f(x) = 0##. By continuity again also ##f(0) = 0##, so ##f=0## everywhere.
So, to answer your question concretely, I don't think doing part (b) separately is necessary.
Note that eigenvalue ##\lambda = 0## can only happen when ##A## is non-injective. This map is injective however (continuity is key again here). Maybe that's what (b) wants you to write?
Likes member 428835
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 24 ·
