Eigenvalues of the power of a matrix
If λ_i are the eigenvalues of a symmetric matrix A^2, then the eigenvalues of A must be either √λ or -√λ. This means that for each eigenvalue of A^2, there are corresponding eigenvalues for A. Since A is symmetric, all eigenvalues must be real, which implies that the eigenvalues of A^2 are non-negative. The discussion also highlights that both √λ and -√λ can be eigenvalues of A, as demonstrated by the example matrix A = [[2, 0], [0, -2]]. Thus, the eigenvalues of A^2 being positive confirms that A has real eigenvalues.
IniquiTrance
If \lambda_i are the eigenvalues of a matrix A^2, and A is symmetric, then what can you say about the eigenvalues of A?
I know how to prove that if \sqrt(\lambda_i) is an eigenvalue of A, then \lambda_i is an eigenvalue of A^2.
I don't know how to prove the converse though.
Thanks!
Let \lambda be an eigenvalue of A^2. What can you say about A^2-\lambda I?
Now, use that
A^2-\lambda I=(A-\sqrt{\lambda}I)(A+\sqrt{\lambda} I)
Now, use that
Then:
det(A-\sqrt{\lambda}I)*det(A+\sqrt{\lambda} I) = 0
Not sure how to proceed...
If xy=0, then what can you say about x or y?
Oh so all we can say is that either \sqrt{\lambda} or -\sqrt{\lambda} is an eigenvalue of A, but not both?
Right.
Thank you.
One more question, how do we know that all the eigenvalues of A^2 are positive? Since A is symmetric, if \lambda < 0 were an eigenevalue of A^2 we'd run into a problem...
We can do the same with \sqrt{\lambda} complex numbers, no?
But since A is symmetric, it must have real eigenvalues, no?
Yes, sure. So what we do is we argue the same argument where \lambda might be negative and where \sqrt{\lambda} might be complex. Then we can deduce that either \sqrt{\lambda} or -\sqrt{\lambda} are eigenvalues of A. Since A is symmetric, we have that \sqrt{\lambda} must be real, so \lambda was positive to begin with.
Ah ok, thanks again!
No, you can have both. The matrix
A = \pmatrix{2 & 0 \\0 & -2} has
B = A^2 = \pmatrix{4 & 0 \\0 & 4},
and so both \sqrt{4} and -\sqrt{4} are eigenvalues of A.
RGV
  • · Replies 19 ·
