Eigenvalues of two matrices are equal
  • Context: Graduate
  • Thread starter Thread starter gopi9
    Eigenvalues Matrices
The discussion revolves around the eigenvalues of two matrices, A and B, with a focus on proving that two of their eigenvalues are equal and that the remaining two eigenvalues of matrix A are both 1. Participants explore theoretical approaches, calculations of determinants, and characteristic polynomials, while addressing potential errors in the problem statement.
  • One participant presents matrices A and B and seeks to prove that two eigenvalues are equal and that A has two eigenvalues of 1.
  • Another suggests finding the characteristic polynomials of A and B as a method to approach the problem.
  • A participant shares their derived characteristic polynomial for A and notes difficulties in factorization, while providing the polynomial for B.
  • Concerns are raised about the correctness of the original problem statement, particularly regarding the roots of the polynomial for A.
  • One participant mentions that MATLAB indicates -1 as an eigenvalue, despite their theoretical proof appearing correct.
  • Another participant proposes a simpler example with all parameters set to zero, suggesting a potential issue with the original question.
  • A later reply discusses rearranging matrix A and notes that A' has two eigenvalues of 1, while questioning the eigenvalues of B.
  • Participants discuss the relationship between eigenvectors of matrices A and B, with suggestions to explore specific forms of vectors.
  • There are mentions of the complexities introduced by the parameters a, b, c, and d in determining eigenvectors and their relationships.
  • One participant suggests that A and B are block matrices, proposing a method to find their characteristic polynomials based on this structure.
Participants express differing views on the correctness of the original problem statement and the factorization of the characteristic polynomial for matrix A. There is no consensus on the eigenvalues or eigenvectors, and the discussion remains unresolved regarding the relationships between the matrices.
Participants note potential issues with the problem statement, including the possibility of missing signs in matrix A. There are also unresolved mathematical steps related to the factorization of characteristic polynomials and the implications of specific values for a, b, c, and d.
gopi9
Hi everyone,
I have two matrices A and B,
A=[0 0 1 0; 0 0 0 1; a b a b; c d c d] and B=[0 0 0 0; 0 0 0 0; 0 0 a b; 0 0 c d].
I have to proves theoretically that two of the eigenvalues of A and B are equal and remaining two eigenvalues of A are 1,1.
I tried it by calculating the determinant of A and B and I got close to the result but I am not able to prove it completely.
I got result like this,
sum of roots of determinant of A and B as
p+q+r+s=p1+q1 (p,q,r,s are roots of det of A, p1,q1 are roots of det of B)
Product of roots
p*q*r*s=p1*q1
pqr+qrs+prs+pqs=-2(p1*q1).
Please help me to show that two eigenvalues of A and B are equal.
Thanks.
Find the characteristic polynomials of A and B.
Then factorize A - the question tells you two of the factors.
I already tried that way.
The characteristic equations that I got for A is
p^4 - p^3(a+d) + p^2(ad-bc-a-d) +p (2ad-2bc) +ad-bc=0
and
for B
p^4-p^3(a+d)+p^2(ad-bc)=0
I can't factorize A polynomial equation, since it does not have simple 1 or -1 as roots.
The question says two roots of the A polynomial are equal to 1. So if (p-1)^2 isn't a factor, either you made a mistake somewhere, or the question is wrong.
I agree with you that p-1 us not a factor of the A polynomial, so I think the question in your OP is wrong. Are you missing some minus signs in the A matrix?
Matlab gives -1 as an eigenvalue but theoretically i can't prove it. There is no mistake in the theoretical proof, i checked it many times. The signs in A matrix are also correct.
This is an example of A matrix that I have
0 0 1 0
0 0 0 1
-400000 200000 -400000 200000
66666.67 -133333.33 66666.67 -133333.33
I took a=-400000, b=200000, c=66666.67, d= -133333.33
Take the simpler example of a = b = c = d = 0.
There is obviously something wrong with the question here.
Switching around the rows you have A' = ##
\begin{pmatrix}
a & b & a & b\\
c & d & c & d\\
0 & 0 & 1 & 0\\
0 & 0 & 0 & 1\\
\end{pmatrix}## and B = ##\begin{pmatrix}
0 & 0 & 0 & 0\\
0 &0 & 0 & 0\\
0 & 0 & a & b\\
0 & 0 & c & d\\
\end{pmatrix}##
Clearly A' has two eigenvalues of 1 -- they are sitting right there on the diagonal; Since A' was obtained by switching each row and even number of times, the eigenvalues of A' are those of A. Clearly also B has two eigenvalues of 0. What are the other eigenvalues of B? If b = c = 0 then they are a and d. If b and c are 0 a and d will also be the eigenvalues of A. You will want to show this, but the computation should be easy with all those zeros in it.
However, b and c don't have to be 0. My guess would be that the 2 eigenvalues of ##\begin{pmatrix}
a & b\\
c & d\\
\end{pmatrix}## will also be the other two eigenvalues of A.
Can you show that?
In my case a,b,c,d are not zeros alephzero. Thanks for the reply
Thanks brmath. That helps
Can we obtain relation between eigenvectors of A and B matrices
Will try to get back to you later today.
Take brmath's re-arranged matrix A' and consider vectors of the form (x,y,0,0).
Thanks for the reply.I did not understand what u meant by consider vectors of the form (x,y,0,0). I already tried using A' matrix to solve it but could not go any further.
For the example that I took A has eigenvectors
[2.206e-6 6.008e-6 0.6912 -0.3835;
-4.749e-7 9.304e-6 -0.1487 -0.5940;
-0.9776 -0.5424 -0.6912 0.3835;
0.2104 -0.84007 0.1487 0.5940]
and B has
[0 0 1 0;
0 0 0 1;
-0.9776 -0.5424 0 0;
0.2104 -0.84007 0 0].
Eigenvectors of [a b; c d] is
[-0.9776 -0.5424;
0.21043 -0.84007]
The eigenvectors present a different kind of problem, and there are a number of different possibilities.
I suggest you start by finding the eigenvectors of B which match the 0 eigenvalues: i.e. Bx = 0. You will get either one or two different x's. I suspect just one.
With the A there are numerous possibilities, which depend on the a, b, c, and d. For example if a = c = 1 and b = d = 0, A will probably have four independent eigenvectors all corresponding to the single eigenvalue 1. If you have a = b = d = 1 and c = 0, A will probably have 3 eigenvectors corresponding to the eigenvalue 1. You will have to work this out.
In either of these cases, B will also have eigenvectors corresponding to 1 - -either two independent ones, or just one.
Whether any of these eigenvectors match up between A and B is something you will have to compute. That is, find the eigenvectors of A which correspond to 1 under the two a,b,c,d scenarios I suggested, and find the eigenvectors of B for those same 1's.
Offhand I see no particular reason to believe they are the same or different -- you'll have to see.
Now the x's that match with the zero eigenvalues of B might or might not be eigenvalues of A. It could be that they are for some values of a,b,c,d and likely not for others. But you should check by multiplying the x's by A.
Once you've gotten through all that, you may have a clue as to whether anything matches up for other values of a,b,c,d.
Calculate A'(x,y,0,0)t and you should notice that it looks a lot like a 2x2 matrix operating on a two dimensional vector.
It does, but I think the a,b,c,d create a lot of complications.
A and B are block matrices. So are xI-A and xI-B. Does that give you a way to find their characteristic polynomials? If I have to guess:
charpoly(B,x) = x^2((x-a)(x-d) -bc) and charpoly(A,x)=(x-1)(x-1)((x-a)(x-d) -bc)
so both charpoly(A) and charpoly(B) have common (quadratic) factors ((x-a)(x-d) -bc) .
  • · Replies 16 ·
  • · Replies 23 ·
