Elastic collision between pool balls
7 replies · 3K views
John004
A super cue ball is made of the same material with the target ball (radius r) but slightly larger: rc = (3)^(1/3)*r The cue ball collides with the target ball on a frictionless table, as shown below, with initial speed of v0. The collision is not head-on, as shown below.
a) What are the velocities of the two balls after the collision? You need to determine both the speeds and directions!
b) In the CM frame, what is the target ball’s direction, relative to the x-axis?
ρ = m/V
ρ = 4/3 π r3
[/B]
so for the masses,
m1 = ρV1 , m2 = ρV2
taking the ratio of those guys gives m1 = 3 m2
if i use conservation of linear momentum and kinetic energy conservation, i end up with two sets of equations but one is a vector equation and the other is not, so i don't know how to even start this problem
ρ = m/V
ρ = 4/3 π r3
[/B]
so for the masses,
m1 = ρV1 , m2 = ρV2
There should be a figure to the problem. Attach it please!
The vector equation can be written as two scalar equations for the components of the linear momentum. So you have three equations.
Oh right! its there now.
OK. So the velocity of the target ball encloses the angle pi/3 with the original velocity of the cue ball after the collision. The direction of velocity of the cue ball is unknown after collision. And energy is conserved. Write the equations for the components of the momenta, and also for the conservation of energy.
Ok so this is what I've done so far
m1<u1x,u1y> = m1<v1x, v1y> + m2<v2x, v2y>
where u1 is the velocity of mass 1 before the collision, v1 is the velocity of mass 1 afterwards, and similarly for mass 2.
I end up with
(√3)/6 v2 + v1cos(φ) = v0 where v0 = u1x these are the magnitudes of the velocities
v2 = -(6/√3)v1sin(φ)
and then the energy conservation expression
3v02 = 3v12 + v22
does this look ok so far?
John004 said:
I end up with
Check the equations, there are mistakes in both.
3v02 = 3v12 + v22
The energy equation is OK.
m1<u1x, 0> = m1<v1x, v1y> + m2<v2x, v2y>
<m1u1x, 0> = <m1v1x, m1v1y> + <m2v2x, m2v2y>
<m1u1x, 0> = < m1v1x + m2v2x, m1v1y + m2v2y>
therefore,
m1v1x + m2v2x = m1v0
m1v1y = -m2v2y
3v1cos(φ) + ½v2 = 3v0
v2 = -(6/√3)v1sin(φ) still got the same thing for this one
It is OK. But do not forget, that you get negative angle φ. The cue ball moves under the x-axis after collision.
Isolate cos(φ) and sin(φ), square and add the equations, so as φ eliminates.
