Electric Arc Lighter: Solving Transformer Overcurrent Issues
  • Thread starter lukakopa7
21 replies · 3K views · last reply
lukakopa7
Hi. I am making an electric lighter which uses 3.7v LiPo battery(600mah), TP4056 battery protection (short circuit, overcurrent(3 Amp)) charging module, switch and 25kV transformer. The problem is that transformer has spikes that are over 3 amps and overcurrent protection gets triggered. I could bypass protection features but transformer works till batteries are discharged way to low(2.3V). Any ideas?
So... You have a 25kV transformer that can draws 3A at 3.7V (~10W) and your asking about bypassing "protection features" so that you can ignite things?
I feel safe to say that there is zero chance we will want to help you do that. Anyway, not me at least.
Some projects fall into that category "if you have to ask for help, your not qualified to do it." Please be careful.
PS: you might review the PF rules about dangerous things.
If this is for a sealed BBQ lighter? Please define your design specs rather than a general description of some parts and failures with a part you may not need.
What other inputs besides 600 mAh LiPo?
What output do you need? Estimate longevity or number of uses or ignition arcs
lukakopa7 said:
25kV transformer
Drop that.
By the time you transform 3.6V to some high voltage like that it's not just dangerous, but practically useless in this kind of function.
Rive said:
Drop that.
Not necessarily. A step-up auto-transformer used in flyback mode keeps low voltage on a button switch and high voltage on the arc. The trick is to choose the inductance and Rs on the primary to limit the current. The breakdown voltages and gap must break the holding current so it does not persist when released. The 25kV means it can generate at least an arc of 25 mm under humid conditions of 1 kV/mm. Winding capacitance and high permeability cores can degrade the voltage, so often air coils are used in furnace gas igniters.
no solution is possible without goals and eng specs.
Humm... guess I not a smart as I thought.
TonyStewart said:
Not necessarily.
If a '25kV transformer' pops up in these kind of suicidal type DIY projects then it's most likely some tesla coil or a salvaged piece of hardware from an old TV set => both are useless and just dangerous.
So: indeed not 'necessarily', but in case of staying case-relevant it's around 99.9%.
Well, as long as that 25kV stays, I sure won't provide anything but solid 'don't do that' o0)
If the OP reconsiders then we'll see.
It's good to warn on safety but a 600 mAh battery is hardly a good source for a defibrillator but can be painful. But I'm sure some could make it lethal. I prefer not to assume the IQ of the writers.
It's about all the readers.
Reminds me of Grade 10 electrical shop. My partner asked teacher, "can I touch this? "Yes" ... Oww.. "You said can.. not should." As a rule I propose we should never offer advice or solutions to DIY or design questions until "intent" and "design specs" or "acceptance criteria with all in & outs " exist in the original question.
Hi. I m building jet powered rc plane and i need source of constant ignition.
Welcome to PF.
What are you trying to ignite?
Maybe you could use a particular wavelength IR laser diode to ignite a gas.
I would look for motorcycle ignition systems, then: with the high voltage parts intact and untouched, safe.
Baluncore said:
Welcome to PF.
Im using mixture of liquid butane and methanol. Yeah but device has to be small and light.
Yes but it is much heavier.
Then a mower, chainshaw or such.
Are you sure that the classic glow plug igniters used on RC models can't do the trick?
Laser diodes are small and could produce a wavelength that would be strongly absorbed by the fuel, resulting in ignition.
Have you considered a glow plug in a combustion chamber, one that remains hot once the engine is running.
I already tried glow plug from old Volkswagen golf but it uses much more power and when it got hot it melted all cables.
I already tried glow plug from old Volkswagen golf but it uses much more power and when it got hot it melted all cables. I already tried smaller glow plugs but it does not stay at the temperature of ignition because of the cold fuel.
lukakopa7 said:
I already tried glow plug from old Volkswagen golf ...
I recommend an exposed filament glow plug, as used for model airplane engines, not a glow plug from a diesel engine motor vehicle.
Search eBay 'glow plug igniter'
or 'Glow Plug Standard OS No.8'
Position in the combustion chamber is everything.
While some of us here at PF have done professional designs at that HV level, most have not. And as noted earlier, we need to be careful about folks who come along later and read these kinds of therad. This thread falls under the "dangerous discussion" prohibition in the PF rules, so will remain closed.
