Electric Current in a Capacitor: What is it Called?
The discussion revolves around the nature of electric current in capacitors, specifically addressing the terminology used to describe the current that exists between the plates of a capacitor and how alternating current (AC) interacts with capacitors. The scope includes theoretical concepts and technical explanations related to electric fields and charge dynamics in capacitors.
  • One participant inquires about the term for the current that flows through the space between capacitor plates.
  • Another participant suggests the term "displacement current" as a possible answer.
  • A participant explains that no current flows "through" the capacitor; instead, current creates a charge that establishes an electric field, which influences the charge on the opposite plate.
  • Multiple participants question how AC can pass through a capacitor, with one asserting that AC does not pass through because it involves alternating polarity on the capacitor plates.
  • Another participant elaborates that while AC charges and discharges the plates, it is the interaction of current, charge, and electric field that creates the appearance of current passing through.
  • A mathematical relationship is presented, indicating that changes in charge over time relate to the current at the plates.
Participants express differing views on whether current can be said to "pass through" a capacitor, with some asserting it does not while others describe the dynamics of charge and field interactions. The discussion remains unresolved regarding the implications of AC in capacitors.
There are limitations in the assumptions about current flow and the definitions of displacement current and related terms. The discussion does not resolve the complexities of AC behavior in capacitors.
Chemist@
How is the current that pushes electricity through the space between the two plates of the capacitor called?
Are you thinking of "displacement current"?
Yes, thank you.
How is this current connected to the turbulent current and the surface current?
No current is flowing "through" the capacitor. Current flowing onto one plate creates a charge which sets up an electric field which again repels some charge on the other plate. Therefore you can "load" the capacitor with a charge by connecting it to a voltage source. You can then transport this charge by disconnecting the capacitor and moving it somewhere else.
But why and how does AC pass through the capacitor?
It doesn't, because AC is cycling, the polarity of the charge on each of the plates of the capacitor is also constantly alternating
at the frequency of the AC signal (voltage)
Dave
It does not. An alternating current will charge and discharge one plate, which means that the electrical field will change which again will change the charge on the other plate. A change in the charge means that a current will pass out of or come onto the plate. Thus, it seems as if current "passes through", but in reality it is interaction between current, charge and field.
To repeat the basics: Q = C*V. If things change over time, you get dQ/dt = C*dV/dt, and dQ/dt is the current out of or onto the plate.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 103 ·
9K
