Electric Dipole Energy Outside Sphere
  • Thread starter Thread starter Jake 7174
    Dipole Energy
The problem involves calculating the total energy of an electric dipole, consisting of charges ±q separated by distance d, enclosed within a spherical region of radius a. The dipole is centered at the origin, and the task is to find the energy outside the sphere.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to perform integrals to find energy, with some questioning the limits of integration due to potential division by zero. There is uncertainty about how to handle the energy calculation both outside and inside the sphere.
Some participants have offered guidance on calculating the electric field due to the dipole and integrating for energy density. There is ongoing exploration of the implications of the mathematical expressions involved, particularly regarding the limits of integration and the behavior of the energy calculation.
Participants note the challenge of integrating over a spherical region and the potential for infinite energy calculations, which raises questions about the physical interpretation of the problem. There is acknowledgment of the limitations in understanding electrostatics as it relates to point charges and dipoles.
Jake 7174
An electric dipole with charge ±q is separated by distance d. This dipole is enclosed in a spherical space of radius r = a such that the center of the dipole is located at the origin and the entire dipole in encased in the space. In other words the charges are at ±d/2 and a > d/2 Find the total energy everywhere outside the sphere.
WE = ∫∫∫ 1/2 ε0 E2 dv
Edipole = Qd cosθ ar / (2 π ε0 r3) + Qd sinθ aθ / (4 π ε0 r3)
Where ar and aθ are unit vectors.
I know I must do the above integral twice. I need to first do this to ∞ and again with the spherical space. My answer will be the difference between the two. I am having issue because this was something that is not in the text. We only covered briefly in lecture.
I think I have a problem with my approach. I first want to find the energy to infinity. So I do this
ε0/2 ∫∫∫ Qd cosθ ar / (2 π ε0 r3) + Qd sinθ aθ / (4 π ε0 r3) dr from r=0 to ∞ dθ from θ=0 to π dφ from φ=0 to 2π
The result of this blows up due to the 0 in the limits of the first integral. Not sure what to do about this. I suppose I could set my limits from r = a to infinity. I guess this would result in my answer provided my equations listed in the equation section are valid. This leaves a huge question in my understanding however. What if I were asked for the energy in just the sphere? Then my limits would have to have the 0.
Jake 7174 said:
My big issue with this is finding E. I am not sure how to do this for a spherical region. E varies with 1/r2. But the radius in this case varies. How do I begin with this?
i think first you should calculate field E due to a dipole at any point (r,theta) , and go ahead with integration for the field energy as your expression seems to be 'integration of energy density over whole space - let us see !
Isn't the expression Qd cosθ ar / (2 π ε0 r3) + Qd sinθ aθ / (4 π ε0 r3) valid for the E field at any r or θ in spherical coordinate system?
I think you've stumbled upon a curious and perhaps "embarrassing" (David J. Griffiths calls it "embarrassing" in his book, Introduction to Electrodynamics) limitation in our (humans) current understanding of electrostatics.
It's not limited to dipoles either. Ask yourself instead, how much energy does it take to make a single point particle like an electron? [integrate [itex]\frac{1}{2} \varepsilon_0 \left( \frac{q}{4 \pi \varepsilon_0 r^2} \right)^2[/itex] over all space] You'll also find that even that takes an infinite amount of energy.
i can not confirm as the expression looks similar but you have magnitude of E as its E^2 in the integrand so take care otherwise your calculation will get affected- i remember some factor sqrt(1 + 3 cos^2 theta) in the numerator - try to do full calculation
It's not limited to dipoles either. Ask yourself instead, how much energy does it take to make a single point particle like an electron? [integrate [itex]\frac{1}{2} \varepsilon_0 \left( \frac{q}{4 \pi \varepsilon_0 r^2} \right)^2[/itex] over all space] You'll also find that that even takes an infinite amount of energy.
Good point. That goes to infinity as well. This is probably why my professor asked us to do this problem. It is just something he scribbled on the board as we were packing up.
Right. I left the ^2 off as a simple copy and paste error. This still does not change the fact that I will have division by zero once the integration is carried out.
Yeah, I don't think you can get around that.
That's probably why the question only asked you to find the energy outside of the sphere. You'll end up with nonsensical answers inside.
so a good 'learning exercise' given by your teacher - now it will never leave your 'thumb rule book'.
So does this equation look ok then;
ε0/2 ∫∫∫ [ Qd cosθ ar / (2 π ε0 r3) + Qd sinθ aθ / (4 π ε0 r3) ] 2 dr from r=a to ∞ dθ from θ=0 to π dφ from φ=0 to 2π
indeed
Assuming that [itex]\vec E = \frac{Qd}{2 \pi \epsilon_0 r^3}\cos \theta \hat{a_r} + \frac{Qd}{4 \pi \epsilon_0 r^3}\sin \theta \hat{a_\theta}[/itex] (which I haven't verified), then that looks about right.
You can distribute the squaring operation into the individual components by invoking the Pythagorean theorem.
[Edit: Oh, and your differentials shouldn't be just [itex]dr[/itex], but rather something a bit more complicated noting that [itex]d \vec r = (dr) \hat {a_r} + (r d \theta) \hat {a_\theta} + (r \sin \theta d \phi) \hat {a_\phi}[/itex], if that's not what you already meant by "dr".]
  • · Replies 17 ·
