Electric field and electron acceleration
The discussion focuses on calculating the acceleration of an electron in an electric field of 6900 N/C directed north. Using the formula m \vec{a} = -eE \hat{y}, the acceleration is derived as \vec{a} = \frac{-eE}{m} \hat{y}, indicating that the acceleration direction is south. Additionally, the conversation addresses finding the point on the x-axis where the electric field from two point charges, q1 = +20.0 nC and q2 = +11.0 nC, equals zero, emphasizing the need to consider the vector nature of electric fields and the distances involved.
  • Understanding of electric fields and forces, specifically the equation F=qE.
  • Knowledge of basic physics concepts such as mass, charge, and acceleration.
  • Familiarity with vector addition and cancellation in electric fields.
  • Ability to apply Coulomb's law, E=k[q]/r^2, in electric field calculations.
  • Explore the concept of electric field lines and their representation.
  • Study the principles of superposition in electric fields.
  • Learn how to solve for electric field strength in multi-charge systems.
  • Investigate the relationship between electric fields and potential energy.
Students and educators in physics, electrical engineers, and anyone interested in understanding electric fields and forces in charged particle dynamics.
kong12
What are the magnitude and direction of the acceleration of an electron at a point where the electric field has magnitude 6900 N/C and is directed due north?
label the north direction as \hat{y} so \vec{E}=E \hat{y}. The "electric force" equals the charge times the electric field. that is,
where e is the charge of the electron and m is its mass.
that would then make the direction south? i found my answer by using F=qE and the F=ma. and i have another question...
Two point charges, q1 = +20.0 nC and q2 = +11.0 nC, are located on the x-axis at x = 0 and x = 1.00 m, respectively. Where on the x-axis is the electric field equal to zero? i wanted to use the equation E=k[q]/r^2 but I'm confused as to what to do with the x=0 and x=1
You can use the x values to determine the distance (r) between the two charges.
i am not sure how to encorporate the the one formula with the various values
Note that electric fields are vectors. For the field to cancel at a point, the field due to A should cancel out the field due to B. Where do you think that could happen (between A and B / left of A / right of B)? Once you figure that out, take a point 'x', and find out x for Eax = Ebx.
