Electric field as a function - potential
3 replies · 6K views · last reply
scholio
electric field as a function -- potential
assume that the electric field in space is given by E = E_o*e^(-r/R) where r is the radial distance away from the origin and E_o and R are constants. E points away fro the origin. Calculate the electric potential at any point r if zero potential is taken at r = +infinity.
i should get electric potential V(r) = E_o*R*e^(-r/R)
point charge electric potential V = V(r) = kq/r where k is constant = 9*10^9, q is charge, r is distance
electric potential difference deltaV_AB = V_B =V_A = - [<integral>E*dr] from r_A to r_B
what does it mean that E points away from the origin, how does knowing that affect the problem?
what is the integral of the E function, how integrate the e^(-r/R) portion specifically?
if i let r = infinity, then in the E function then e^(-infinity) = 0, so the function goes to zero
any tips on how to get started appreciated...
scholio,
The integral is:
[tex] \Delta V_{ab} = -\int\limits_{a}^{b} \vec E\cdot d\vec r[/tex]
and so since there is a dot product inside the integral, you need to know the (relative) directions of [itex]d\vec r[/itex] and [itex]\vec E[/itex] in order to write down the integral for this particular problem.
the problem states that E points away from the origin. and r is the radial distance away from the origin. so does that make E negative and dr positive?
so now do i sub in the function in for E in the integral, how do i integrate e^(-r/R)?
since i want to calculate for electric potential V, is the charge at the origin, thus a point charge?
No, it means that r and E both point in the same direction- so their dot product is just the product of their lengths.
Use the substitution u= r/R.
??There is no mention of a "charge at the origin", just an electric force field- no mention of what causes the force field.
