Electric Field at Point P in an Equilateral Triangle
2 replies · 3K views
Kathi201
Three positive and equal charges Q1, Q2, and Q3 are at the corners of an equilateral triangle. Point P is at the midpoint of the line between Q1 and Q3 (the middle of the bottom of the equilateral triangle). The electric field at P is
A.zero
b. not zero and directed along the line from P to Q3
c.not zero and is directed along the line from P to Q2
d. not zero and is directed along the line from Q1 to Q2
E.none of these are correct
My thinking is that the answer is zero. I know that the electric field points away from positive charges so if Q1 and Q3 are at the bottom of the equilateral triangle the P is in the middle they are going to direct the opposite way and cancel each other out.
Anybody know if this is correct or have a reason why another answer would be correct?
Hi Kathi201,
A.zero
You're right that the electric field from Q1 and Q3 are going to cancel. But what about the field at P from Q2?
Oh Ok thank you I forgot about Charge Q2. So the electric field at P is going to be directed along the line from P to Q2.
Thanks for your help
