Electric field due to charges between 2 parallel infinite planes
  • Thread starter Thread starter Tesla In Person
The discussion revolves around finding the electric field due to charges between two parallel infinite planes using Gauss's law. The original poster describes a setup involving a uniform charge density and a Gaussian surface shaped as a cube. The problem is situated within the context of electrostatics and field theory.
  • The original poster attempts to apply Gauss's law to derive the electric field, expressing uncertainty about the correctness of their calculations. Some participants question the assumptions made regarding the Gaussian surface and the implications of translational invariance. Others suggest considering the electric field in different regions relative to the charge distribution and inquire about the conditions under which the electric field might be zero.
Participants are actively engaging with the problem, raising questions about the setup and the implications of the electric field's direction in various regions. There is an exploration of the electric field's behavior at specific points, such as the origin, and discussions about the rendering of LaTeX in the forum context. No consensus has been reached yet, but there is a productive exchange of ideas and hints regarding the electric field's characteristics.
Participants note issues with LaTeX rendering in the forum, which affects the clarity of mathematical expressions. The discussion also highlights the need to consider multiple regions of space when analyzing the electric field, indicating a complexity in the problem that may require further exploration.
Tesla In Person
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point
Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A.
I know that the field depends only on z since there is translational invariance in x and y directions because the planes are infinite.
So applying gauss law : Q_enc is the volume of the cube of side a and face area A. That gives Q_enc= p*A*a and left hand side of gauss's law gives 2*A*E. I excluded the areas facing y and x directions since the field is pointing in the z direction so only the 2 faces facing in that direction are cut be the field lines. I get 2AE = p*A*a / epsilon and simplifying this gives E = p*a / 2*epsilon. I'm not sure if this is correct. If it's incorrect, I want to know where I made mistakes. I'm doing this for the first time and I'm struggling with these question especially when I have to find the right gaussian surface for the problem.
Your attachments did not seem to work. Can you try again? What file type are they?
I don't know why they are not opening , Hope its fixed now. Its png files.
Tesla In Person said:
. . . and left hand side of gauss's law gives 2*A*E.
There are three regions of space:
  1. Inside the distribution ##~-\frac{a}{2} \leq z \leq\frac{a}{2}##
  2. To the left of the distribution: ##~z\leq-\frac{a}{2}##
  3. To the right of the distribution: ##~z\geq\frac{a}{2}##.
You need to find the electric field in each region. This means writing the electric field vector ##\mathbf E(z)## as a function of ##z##.
Hint: Is there a value of ##z## at which the electric field is zero?
Is it zero at the origin , z=0? But why would it be 0 at the origin , is it just a convention or is the strength of the electric field really 0 there ? The LaTeX doesn't appear in the message so I don't understand the points 1. 2. and 3.
For some reason the LaTeX works in "Preview" mode only. Here it is
Answer the following four questions and you will see why the electric field is zero at z = 0.
  1. In what direction does the electric field point in region 2, to the left of the distribution?
  2. In what direction does the electric field point in region 3, to the right of the distribution?
  3. In what direction does the electric field point inside the slab, to the left of the origin?
  4. In what direction does the electric field point inside the slab, to the right of the origin?
My experience has been that using preview mode destroys LaTeX rendering. It's a known issue.
It appears to be more complicated than that. I had a PM exchange with Greg and he observed that it might be the inclusion of LaTeX in an ordered list that messes up the rendering. An additional complication is that this appears to happen with posts on regular threads but not PM messages where LaTeX renders correctly. I haven't heard from Greg lately, but I'm sure he's on it.
Below is a screenshot of the preview of a test post. Everything looks good.
Here is a screenshot of the posted reply (since deleted). The "No ordering" LaTeX has been rendered correctly but not the rest. If I put this in a PM, all of it will be rendered.
Oh I see, they are pointing in opposite directions in all these regions so the electric field ends up cancelling out.
Cancelling out where?
Do you see what you need to do to find the electric field, magnitude and direction, for all values of ##z##?
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 18 ·
