Electric Field Halfway Between Two Charges
4 replies · 3K views
Xet
q1 (-6.5E-7 C) @ 6 cm to the right of origin (X,Y coordinate is 6,0)
q2 (6.5E-7 C) @ 21 cm to the left of origin (X,Y coordinate is -21,0)
At the half-way point of these two charges, what is the E field value...?
sum of electric fields
electric field at point is equal to constant times the charge, all divided by radius squared
constant is 8.99E9 Nmm/(CC)
I found the two E's from the point to the half-way mark...I'm suppose to add the two E's because it's going from negative to positive...right? Well...I got it wrong...
What did you use for the distance when you calculated the E field?
Rather dumb question to ask...but I used .135 m as R.
It is not a dumb question at all. You didn't show your work. How can we tell you what you did wrong if you don't show any calculations?
well, if it's a dumb question to ask I won't ask any question anymore.
Best luck
