How to Calculate Electric Field at the Center of Curvature of a Hemisphere?
The electric field at the center of curvature of a uniformly charged hemisphere can be calculated using the surface charge density, sigma, defined as sigma = Q/(2*PI*r^2). To find the electric field, the hemisphere is divided into rings, each carrying a charge dQ = sigma * 2*PI*dr. At the center of curvature, the electric field components perpendicular to the axis cancel out, leaving only the z-component of the electric field, dE_z, to be expressed in terms of dE. The area element dA in spherical polar coordinates must also be considered for accurate calculations.
  • Understanding of electric fields and charge distributions
  • Familiarity with surface charge density calculations
  • Knowledge of spherical polar coordinates
  • Ability to perform vector decomposition in electric field analysis
  • Study the derivation of electric fields from surface charge distributions
  • Learn about the application of spherical coordinates in electrostatics
  • Explore the concept of electric field components and their vector addition
  • Investigate the principles of symmetry in electric field calculations
Students studying electromagnetism, physics educators, and anyone interested in understanding electric fields generated by charged surfaces.
captainjack2000
Charge Q is distributed uniformly over surface of a hemisphere of radius r. Calculate electric field at centre of curvature of hemisphere.
I realize that this should be quite straightforward but I am a bit confused.
The total charge Q is distributed over surface of hemisphere with surface charge density sigma where
I think you would then divide the hemisphere into a series of rings where each ring would carry a charge
dQ=sigma*2*PI*dr ?
At the centre of curvature the components of electric field perpendicular to the axis will cancel so you will only have electric field along the axis z.
Not quite sure where to go from here.
You're correct in saying that there only is a z-component of the field so express dE_z in terms of dE.
You also know that dQ=\sigma dA. What is dA in spherical polar coordinates? What are the values of \theta and \phi for half a sphere?
